Rectangular Tank with viscoelastic solid inside - help needed |
April 26, 2019, 09:51 |
Sri Nivas Chandrasekaran
Rep Power: 7 |
I am new to OpenFOAM. I want to compare the shear stress (wall and fluid/solid) that occurs when a rectangular tank undergoes linear oscillation (in vertical or z-direction). I was able to do that for the case when the fluid is inside the tank using tutorial 'sloshingTank3D' under the section multiphase with little modification. But for the collagen/viscoelastic solid case, I am using bimaterial plate (plastic and collagen) in the solidDisplacment tutorial in foam ext-4.0. I modified the mesh as required but i am not sure how to apply harmonic oscillation and calculate the wall shear stress in this case. This is a small part in my PhD work to complement the experimental results obtained. Can someone guide me through the process on how to do it? Thanks! |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
Solid object falling in water tank simulation | cassini83 | CFX | 3 | August 9, 2021 17:05 |
Freely solid rotation inside a fluid | Juan Maria | CFX | 0 | April 10, 2008 07:59 |
Howto Sphere solid as a subdomain inside a domain? | jakjak | CFX | 0 | October 24, 2007 23:31 |
simulate a tank equipped with propeller inside | aloha5i | CFX | 0 | October 15, 2005 15:56 |
