December 5, 2019, 14:40 |
Over refined mesh
Rep Power: 6 |
I am having difficulty in optimizing the mesh as I would like. In particular, the mesh is too refined where there are two neighboring surfaces, even if they have the normal facing opposite.
Referring to the attached image, the surfaces C and D are refined because they are close to each other. The same thing happens for surfaces A and B, because they are close to each other, even if there is no fluid volume between the surfaces, and the have opposite normals. Is there a way to prevent refinement between surfaces A and B? Thanks! |
December 6, 2019, 02:34 |
Rep Power: 15 |
Not quite sure how your problem arises. You can define the level of refinement on surfaces in regions, etc, by yourself in snappyHexMesh. I have not yet had issues with automatic refinement that I did not decide on myself. You migh want to consider uploading your snappyHexMeshDict.
December 7, 2019, 04:40 |
#3 | |
Rep Power: 6 |
December 7, 2019, 10:05 |
Rep Power: 15 |
Well you have a refinementBox and 4 regions of a motorbike that are refined. You might want to adjust the dict file according to your case. User guide helpd here.
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
