Alex
Rep Power: 7 ![]() |
Hello everyone,
I need to build a 2d mesh that is basically a vertical rectangle where 3 sides are straight but one (that one on the right) has the shape of a wave (or sine curve). My idea was to build a lot of blocks with blockmesh, like a puzzle, but I do not know if there is a faster way to generate a sinusoidal shape. If you have any suggestion or just a comment please help me. I am quite new in OpenFOAM and I do not know if blockmesh is the right tool for my purpose, in case let me know. |
Rep Power: 15 ![]() |
When you mean 2D, with blockMesh, remember that you will need to have only 1 element in the 3rd direction.... As for creating sine curve, what you can do is to specify a spline between the two vertices in the edges subsection. For example, you could have something like this: Code:
vertices ( (0 0 0) (1 0 0) (1 1 0) (0 1 0) (0 0 1) (1 0 1) (1 1 1) (0 1 1) ); blocks ( hex (0 1 2 3 4 5 6 7) (10 10 1) simpleGrading (1 1 1) ); edges ( spline 2 1 ((0.8 0.75 0) (1 0.5 0) (1.2 0.25 0)) spline 6 5 ((0.8 0.75 1) (1 0.5 1) (1.2 0.25 1)) ); Cheers, Antimony |
Alex
Using "spline" I very easily managed to make the sine curve I was looking for, thank you so much!
curve mesh, wavy channel, wavy fins |
[ICEM] Holes in complex ICEM geometry | alecbann | ANSYS Meshing & Geometry | 2 | April 4, 2019 03:40 |
[Workbench] Workbench 18.2 SpaceClaim->Mechanical geometry accuracy/tolerance problem | sultzan | ANSYS Meshing & Geometry | 0 | December 13, 2018 17:41 |
[GAMBIT] Meshing problem on a simple curved geometry (Gambit Software) | Parham Vatankhah | ANSYS Meshing & Geometry | 3 | February 19, 2018 03:02 |
Export geometry file from ansys mechanical | browns6 | Structural Mechanics | 0 | August 27, 2013 16:19 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
