[Other] Wedge patch '*' is not planar
Like Tree15Likes
  • 1 Post By LilumDaru
  • 11 Post By liquidspoon
  • 2 Post By smrutimaya
  • 1 Post By foadsf
Old   June 18, 2015, 12:41
Default Wedge patch '*' is not planar
Chris
LilumDaru is on a distinguished road
This is about a 2D axissymetric case. I was using a Matlab script to find the edges of the blocks I want to build. (you find the Matlab script in the attachment)
checkMesh gives the output:
Wedge patch 'back' is not planar.
At local face at (0.0685865 -0.001796 0.0021) the normal (-0.0261768 -0.999657 0) differs from the average normal (-0.0261767 -0.999657 -3.31431e-20) by 1.61774e-14
Either correct the patch or split it into planar parts
--> FOAM Warning :
From function wedgePolyPatch::calcGeometry(PstreamBuffers&)
in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 72
At local face at (0.0683891 -0.00179083 0.0172) the normal (-0.0261769 -0.999657 0) differs from the average normal (-0.0261767 -0.999657 -3.31431e-20) by 2.83042e-14
I can't get rid of these error messages. I already tried to change the writePrecision and the writeFormat without any success. Do these errors matter? Can you please help me to eliminate these errors?
blockMeshDict:
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
        (6.497773e-02 -1.701502e-03 0)
        (6.497773e-02 1.701502e-03 0)
        (6.517266e-02 1.706606e-03 0)
        (6.517266e-02 -1.706606e-03 0)
        (6.497773e-02 -1.701502e-03 2.000000e-03)
        (6.497773e-02 1.701502e-03 2.000000e-03)
        (6.517266e-02 1.706606e-03 2.000000e-03)
        (6.517266e-02 -1.706606e-03 2.000000e-03)
        (6.497773e-02 -1.701502e-03 2.200000e-03)
        (6.497773e-02 1.701502e-03 2.200000e-03)
        (6.517266e-02 1.706606e-03 2.200000e-03)
        (6.517266e-02 -1.706606e-03 2.200000e-03)
        (6.537259e-02 -1.711842e-03 2.000000e-03)
        (6.537259e-02 1.711842e-03 2.000000e-03)
        (7.180039e-02 1.880159e-03 2.000000e-03)
        (7.180039e-02 -1.880159e-03 2.000000e-03)
        (6.537259e-02 -1.711842e-03 2.200000e-03)
        (6.537259e-02 1.711842e-03 2.200000e-03)
        (7.180039e-02 1.880159e-03 2.200000e-03)
        (7.180039e-02 -1.880159e-03 2.200000e-03)
        (6.497773e-02 -1.701502e-03 3.220000e-02)
        (6.497773e-02 1.701502e-03 3.220000e-02)
        (7.180039e-02 1.880159e-03 3.220000e-02)
        (7.180039e-02 -1.880159e-03 3.220000e-02)
blocks
	//Block 0
        hex (0 3 2 1 4 7 6 5) (1 1 1) simpleGrading
           1
           1
           1
	//Block 1
        hex (4 7 6 5 8 11 10 9) (1 1 1) simpleGrading
           1
           1
           1
        //Block 2
        hex (7 12 13 6 11 16 17 10) (1 1 1) simpleGrading
           1
           1
           1
        //Block 3
        hex (12 15 14 13 16 19 18 17) (1 1 1) simpleGrading
           1
           1
           1
        //Block 4
        hex (8 19 18 9 20 23 22 21) (1 1 1) simpleGrading
           1
           1
           1
edges();
boundary
    inlet
        type patch;
        faces
            (0 1 2 3) // von innen gesehen gegen den Uhrzeigersinn Aufgezaehlt
    outlet
        type patch;
        faces
            (20 23 22 21)
    shaftInHole
        type wall;
        faces
            (0 1 5 4)
    shaftInFreestream
        type wall;
        faces
            (4 5 9 8)
            (8 9 21 20)
    wallInHole
        type wall;
        faces
            (3 7 6 2)
    wallInFreestream
        type wall;
        faces
            (14 15 19 18)
            (18 19 23 22)
    step
        type wall;
        faces
            (6 7 12 13)
            (14 13 12 15)
    front
        type wedge;
        faces
            (1 2 6 5)
            (5 6 10 9)
            (6 13 17 10)
            (13 14 18 17)
            (9 18 22 21)
    back
        type wedge;
        faces
            (0 4 7 3)
            (4 8 11 7)
            (7 11 16 12)
            (12 16 19 15)
            (8 20 23 19)
mergePatchPairs();
blockMesh:
|  \\    /   O peration     | Version:  2.4.0                                 |
Build  : 2.4.0-f0842aea0e77
Exec   : blockMesh
Date   : Jun 18 2015
Time   : 18:36:28
Host   : "ChrisHP"
PID    : 11568
Case   : /home/chris/OpenFOAM/nowak/Netzerzeugung/NeuesMesh
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Creating block mesh from
    "/home/chris/OpenFOAM/nowak/Netzerzeugung/NeuesMesh/constant/polyMesh/blockMeshDict"
No non-linear edges defined
Creating topology blocks
Creating topology patches
Creating block mesh topology
--> FOAM Warning :
    From function polyMesh::polyMesh(... construct from shapes...)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 903
    Found 4 undefined faces in mesh; adding to default patch.
--> FOAM Warning :
    Wedge patch 'front' is not planar.
At local face at (0.0650752 0.00170405 0.001) the normal (0.0261748 -0.999657 1.32563e-19) differs from the average normal (0.0261767 -0.999657 3.31431e-20) by 3.60957e-12
--> FOAM Warning :
At local face at (0.0650752 0.00170405 0.0021) the normal (0.0261748 -0.999657 1.32563e-18) differs from the average normal (0.0261767 -0.999657 3.31431e-20) by 3.60957e-12
...  (Removed a few similiar Errormessages)
--> FOAM Warning :
At local face at (0.0685865 -0.001796 0.0021) the normal (0.0261768 0.999657 0) differs from the average normal (0.0261767 0.999657 -3.31431e-20) by 1.61774e-14
--> FOAM Warning :
At local face at (0.0683891 -0.00179083 0.0172) the normal (0.0261769 0.999657 0) differs from the average normal (0.0261767 0.999657 -3.31431e-20) by 2.83042e-14
Check topology
	Basic statistics
		Number of internal faces : 3
		Number of boundary faces : 24
		Number of defined boundary faces : 24
		Number of undefined boundary faces : 0
	Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating polyMesh from blockMesh
Creating patches
Creating cells
Creating points with scale 1
    Block 0 cell size :
        i : 0.000194997 .. 0.000194997
        j : 0.003403 .. 0.003403
        k : 0.002 .. 0.002
    Block 1 cell size :
        k : 0.0002 .. 0.0002
    Block 2 cell size :
        i : 0.000199999 .. 0.000199999
        j : 0.00341321 .. 0.00341321
    Block 3 cell size :
        i : 0.00643 .. 0.00643
        j : 0.00342368 .. 0.00342368
    Block 4 cell size :
        i : 0.006825 .. 0.006825
        k : 0.03 .. 0.03
--> FOAM Warning :
At local face at (0.0650752 0.00170405 0.001) the normal (-0.0261748 0.999657 1.32563e-19) differs from the average normal (-0.0261767 0.999657 3.31431e-20) by 3.60957e-12
--> FOAM Warning :
There are no merge patch pairs edges
Writing polyMesh
Mesh Information
  boundingBox: (0.0649777 -0.00188016 0) (0.0718004 0.00188016 0.0322)
  nPoints: 28
  nCells: 5
  nFaces: 27
  nInternalFaces: 3
Patches
  patch 0 (start: 3 size: 1) name: inlet
  patch 1 (start: 4 size: 1) name: outlet
  patch 2 (start: 5 size: 1) name: shaftInHole
  patch 3 (start: 6 size: 2) name: shaftInFreestream
  patch 4 (start: 8 size: 1) name: wallInHole
  patch 5 (start: 9 size: 2) name: wallInFreestream
  patch 6 (start: 11 size: 2) name: step
  patch 7 (start: 13 size: 5) name: front
  patch 8 (start: 18 size: 5) name: back
  patch 9 (start: 23 size: 4) name: defaultFaces
End
checkMesh:
Exec   : checkMesh
Date   : Jun 18 2015
Time   : 18:36:40
Host   : "ChrisHP"
PID    : 11574
nProcs : 1
Create time
Create polyMesh for time = 0
--> FOAM Warning :
--> FOAM Warning :
At local face at (0.0650752 0.00170405 0.0021) the normal (-0.0261748 0.999657 1.32563e-18) differs from the average normal (-0.0261767 0.999657 3.31431e-20) by 3.60957e-12
--> FOAM Warning :
At local face at (0.0652726 0.00170922 0.0021) the normal (-0.0261802 0.999657 -1.29248e-18) differs from the average normal (-0.0261767 0.999657 3.31431e-20) by 1.22804e-11
--> FOAM Warning :
Time = 0
Mesh stats
    internal points:  0
    faces:            27
    internal faces:   3
    cells:            5
    faces per cell:   6
    boundary patches: 10
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     5
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
 ***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
   *Number of regions: 2
    The mesh has multiple regions which are not connected by any face.
  <<Writing region information to "0/cellToRegion"
  <<Writing region 0 with 4 cells to cellSet region0
  <<Writing region 1 with 1 cells to cellSet region1
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    inlet               1        4        ok (non-closed singly connected)
    outlet              1        4        ok (non-closed singly connected)
    shaftInHole         1        4        ok (non-closed singly connected)
    shaftInFreestream   2        8        ok (non-closed singly connected)
    wallInHole          1        4        ok (non-closed singly connected)
    wallInFreestream    2        8        ok (non-closed singly connected)
    step                2        6        ok (non-closed singly connected)
    front               5        14       ok (non-closed singly connected)
    back                5        14       ok (non-closed singly connected)
    defaultFaces        4        12       ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (0.0649777 -0.00188016 0) (0.0718004 0.00188016 0.0322)
    Mesh (non-empty, non-wedge) directions (1 0 1)
    Mesh (non-empty) directions (1 1 0)
    Wedge front with angle 1.49998 degrees
    Wedge back with angle 1.49998 degrees
    All edges aligned with or perpendicular to non-empty directions.
    Boundary openness (2.05835e-17 0 0) OK.
    Max cell openness = 8.2747e-17 OK.
    Max aspect ratio = 30.7004 OK.
    Minimum face area = 3.89994e-08. Maximum face area = 0.00020475.  Face area magnitudes OK.
    Min volume = 1.32868e-10. Max volume = 7.33094e-07.  Total volume = 7.3931e-07.  Cell volumes OK.
    Mesh non-orthogonality Max: 0 average: 0
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.0653982 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
Time = 1
Mesh stats
    internal points:  0
    faces:            27
    internal faces:   3
    cells:            5
    faces per cell:   6
    point zones:      0
    face zones:       0
    cell zones:       0
    hexahedra:     5
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
    Point usage OK.
    Face vertices OK.
  <<Writing region information to "1/cellToRegion"
  <<Writing region 0 with 1 cells to cellSet region0
  <<Writing region 1 with 4 cells to cellSet region1
    Face pyramids OK.
Mesh OK.
End
sourav90 likes this.
LilumDaru is offline   Reply With Quote
Old   June 20, 2015, 03:35
Chris
Ok, Problem was solved by setting the angle to 0 and all y values to -1 or +1. I also changed the type of the front and back surfaces to patch. So I got a 2D plane mesh. In a new case dir I executed extrudeMesh with the wedge options using the front and back patches as input. It worked =)
Old   October 6, 2015, 10:26
Default makeAxialMesh
Antony Premkumar
Antony_Bosco is on a distinguished road
I couldn't really understood how you solved it.
Could you please explain me what angle did you change to 0.
I am also facing the same problem.
Plus my check mesh is showing mesh not OK with seven errors
Antony_Bosco is offline   Reply With Quote
Old   November 24, 2015, 18:32
Alex
liquidspoon is on a distinguished road
Antony: I had some similar issues recently with axisymmetric meshes. I had success switching the writeFormat in controlDict from ascii to binary.
I guess there is some rounding introduced when you convert back and forth from human readable format. It would be nice if there was some place to adjust the precision requirement for wedge planar-ness.
Artur, Icemaan, Danillo and 8 others like this.
liquidspoon is offline   Reply With Quote
Old   May 21, 2016, 07:50
Smile Ignore and proceed to computation
Smrutimaya Pattanaik
smrutimaya is on a distinguished road
Those error messages are not very serious, ignore and proceed to computation.
febriyan91 and Roxana_Laspiur like this.
smrutimaya is offline   Reply With Quote
Old   February 1, 2018, 15:51
Foad
foadsf is on a distinguished road
I had a same issue with an axisymmetric geometry/mesh I created with Gmsh. I reran the gmshToFoam and edited the constant/polyMesh/boundary file manually, changing the wedges type and physicalType to wedge and the noslip walls to wall. it solved the problem and ran smoothly.
Sun likes this.
foadsf is offline   Reply With Quote
Old   January 12, 2021, 05:55
Naveen kumar
2008.naveen is on a distinguished road
I want to do 2d axisymmertic meshing in OpenFoam. But it is showing this error "Either correct the patch or split it into planar parts". Please have a look on it.
2008.naveen is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
steadyUniversalMRFFoam Tutorial fails in MixingPlane HenrikJohansson OpenFOAM Bugs 0 February 14, 2019 04:48
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
