[snappyHexMesh] high skewness cuz of bad mesh at trailing edge NACA0012 |
February 26, 2020, 04:31 |
niewiemnic
Rep Power: 8 |
Hallo,
https://drive.google.com/file/d/1meR...ew?usp=sharing as you can see, there is a little bit problem cuz of weird layer at the trailing edge of NACA0012. Has anyone Idea for the solution? Max. internal face Skewness is about 8. |
February 26, 2020, 07:37 |
anonymous
Hi!
First of all if you visualize your mesh turn the "decompose polyhedra" off in paraView, and in the silces turn the triangulation off also, and you will see the mesh. What you see now is a triangulated mesh, not the real one. In reality it is not that weird, however the boundary layer will collapse there since the mesh would have really poor quality. You can try to refine the trailing edge more, but layering is not an easy to use and trivial feature in snappy. |
February 28, 2020, 05:36 |
#3 | |
niewiemnic
Rep Power: 8 |
[ANSYS Meshing] High Mesh Skewness on Cusp Trailing Edge | jmcquaid | ANSYS Meshing & Geometry | 2 | September 5, 2021 15:12 |
[ICEM] high skewness in volume with low skewness in surface mesh | f.yn | ANSYS Meshing & Geometry | 1 | June 26, 2017 08:57 |
[ANSYS Meshing] 3D Airfoil with Sharp Trailing Edge - Mesh Help | Toofanian | ANSYS Meshing & Geometry | 0 | August 8, 2016 19:54 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Structured mesh of a 3d sharp trailing edge | Gilles | Main CFD Forum | 2 | May 23, 2008 13:23 |
