[blockMesh] blockMesh fails on channel395DFSEM tutorial |
March 6, 2020, 10:14 |
Tom Waits
Rep Power: 7 |
I am using OpenFoam 6 and am running into the following error when attempting to use blockMesh with the channel395DFSEM tutorial:
Using #calcEntry at line 49 in file "/home/tomw/OpenFOAM/tomw-6/run/channel395DFSEM/system/controlDict" Using #codeStream with "/home/tomw/OpenFOAM/tomw-6/run/channel395DFSEM/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_ae1ec7e8a82c67b2acea4bc3aecf74f6f195abcf.so" Invoking "wmake -s libso /home/tomw/OpenFOAM/tomw-6/run/channel395DFSEM/dynamicCode/_ae1ec7e8a82c67b2acea4bc3aecf74f6f195abcf" wmake libso /home/tomw/OpenFOAM/tomw-6/run/channel395DFSEM/dynamicCode/_ae1ec7e8a82c67b2acea4bc3aecf74f6f195abcf Ctoo: codeStreamTemplate.C : In function ‘void Foam::codeStream_ae1ec7e8a82c67b2acea4bc3aecf74f6f195abcf(Foam::Ostream&, const Foam::dictionary&)’: :1:15: error: ‘$’ was not declared in this scope :1:16: error: expected ‘)’ before ‘{’ token /opt/openfoam6/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/codeStreamTemplate.o' failed make: *** [Make/linux64GccDPInt32Opt/codeStreamTemplate.o] Error 1 --> FOAM FATAL IO ERROR: Failed wmake "dynamicCode/_ae1ec7e8a82c67b2acea4bc3aecf74f6f195abcf/platforms/linux64GccDPInt32Opt/lib/libcodeStream_ae1ec7e8a82c67b2acea4bc3aecf74f6f195abcf.so" Last edited by TomWaits; March 9, 2020 at 05:34. |
March 14, 2020, 17:37 |
Herpes Free Engineer
Rep Power: 12 |
i dont think OF6 has DFSEM.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
chtMultiRegionSimpleFoam: Confusion in geometry creation using blockMesh | Struggle_Achieve | OpenFOAM | 8 | July 26, 2016 06:39 |
rhoSimpleFoam angledDuctExplicitFixedCoeff tutorial fails in parallel | donQi | OpenFOAM Running, Solving & CFD | 1 | February 22, 2016 19:47 |
STAR-CD Tutorial | shekhar aryal | STAR-CD | 4 | March 22, 2010 03:25 |
Rotor/stator tutorial, and how to... | gilberto | CFX | 5 | January 21, 2002 09:41 |
