[mesh manipulation] Adding layers to converted fluent mesh |
Jean-Baptiste Parrain
Rep Power: 0 ![]() |
I received a Fluent mesh without any boundary layer. I converted correctly the mesh into OpenFOAM case with the function fluent3DmeshToFoam. Everything is working fine but for the sake of the simulation with kOmegaSST, I need to add boundary layers. Is there a function like the addLayer of snappyHexMesh to do it? Thanks for your help. Cheers |
multiRegionHeater error | ordinary | OpenFOAM Running, Solving & CFD | 2 | June 9, 2020 17:43 |
hybrid mesh created by pointwise fails mesh check in fluent due to left-handed faces | Hamid.de | Pointwise & Gridgen | 4 | November 9, 2016 11:20 |
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting | arunraj | FLUENT | 0 | June 2, 2016 22:58 |
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? | RPjack | ANSYS Meshing & Geometry | 2 | August 27, 2015 09:33 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
