[mesh manipulation] Merged Patches
Old   April 19, 2020, 12:54
Default Merged Patches
Upuli
upuli is on a distinguished road
Hi
I developed a mesh using block mesh. I checked the mesh using 'checkMesh' and there was no error. It contains merged patches. When I open the mesh in paraFoam, I can't see these merged patches (interface1 or interface2) in the 'Mesh Parts' menu and in the mesh. So how can I define boundary conditions on these merged patches. Please help me on this. I couldn't find a solution so far.
Thanking You
Upuli
/*--------------------------------*- C++ -*----------------------------------*/
// File was generated by SwiftBlock, a Blender 3D addon.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1.0;
vertices
(    0.05    0    0    )//0
(    0    0    0    )//1
(    0    0    -1.7    )//2
(    0.05    0    -1.7    )//3
(    0.05    1    0    )//4
(    0    1    0    )//5
(    0    1    -1.7    )//6
(    0.05    1    -1.7    )//7
(    0.2    -0.05    0    )//8
(    0.05    -0.05    0    )//9
(    0.05    -0.05    -1.7    )//10
(    0.2    -0.05    -1.7    )//11
(    0.2    0    0    )//12
(    0.05    0    0    )//13
(    0.05    0    -1.7    )//14
(    0.2    0    -1.7    )//15
(    0.2    1    0    )//16
(    0.05    1    0    )//17
(    0.05    1    -1.7    )//18
(    0.2    1    -1.7    )//19
blocks
hex    (    0    1    5    4    3    2    6    7    )    (    1 20 21    )      simpleGrading (1 1 1)
hex    (    8    9    13    12    11    10    14    15    )    (    3 1 21    )      simpleGrading (1 1 1)
hex    (    12    13    17    16    15    14    18    19    )    (    3 20 21    )      simpleGrading (1 1 1)
patches
    patch AirInlet
    (    0    3    2    1    )
    (    8    11    10    9    )
     patch AirOutlet
(    4    5    6    7    )
(    16    17    18    19    )
  patch FuelInlet
    (2 6 5 1)
 patch FuelInlet2
(    9    10    14    13    )
  patch FuelOutlet
(    8    12    15    11    )
(    12    16    19    15    )
patch interface1
(    13    14    18    17    )
patch interface2
(    0    4    7    3    )
   empty back
(    3    7    6    2    )
(    11    15    14    10    )
(    15    19    18    14    )
empty front
(    4    0    1    5    )
(    12    8    9    13    )
(    16    12    13    17    )
edges
mergePatchPairs
    (interface1 interface2)
upuli is offline   Reply With Quote
Old   April 28, 2020, 13:00
Upuli
Actually I want to merge these two patches into one patch. Does createBaffles can be used for this purpose ? Thank you in advance.
Old   April 29, 2020, 15:57
Luis Eduardo
lebc is on a distinguished road
If you check the coordinates of interface1 and interface2, they have the same points, so they are basically the same thing.
Even by doing this, you can see the merged patch if you enable the option "include zones" in paraview.
Best Regards,
Luis
lebc is offline   Reply With Quote
Old   April 30, 2020, 03:37
Upuli
Hi Luis
Thank you very much for your reply. Is there any method to define a velocity value for the field at the merged patches. I want to define a velocity at the interface of this block1 and block3 (interface1 and interface2).
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
vertices
(    0.05    0    0    )//0
(    0    0    0    )//1
(    0    0    -1.7    )//2
(    0.05    0    -1.7    )//3
(    0.05    1    0    )//4
(    0    1    0    )//5
(    0    1    -1.7    )//6
(    0.05    1    -1.7    )//7
(    0.2    -0.05    0    )//8
(    0.05    -0.05    0    )//9
(    0.2    0    0    )//12
(    0.05    0    0    )//13
(    0.05    0    -1.7    )//14
(    0.2    0    -1.7    )//15
(    0.2    1    0    )//16
(    0.05    1    0    )//17
(    0.05    1    -1.7    )//18
(    0.2    1    -1.7    )//19
blocks
hex    (    0    1    5    4    3    2    6    7    ) block1   (    1 20 21    )      simpleGrading (1 1 1)
hex    (    8    9    13    12    11    10    14    15    )  block2  (    3 1 21    )      simpleGrading (1 1 1)
hex    (    12    13    17    16    15    14    18    19    )  block3  (    3 20 21    )      simpleGrading (1 1 1)
patches
    patch AirInlet
    (    0    3    2    1    )
    (    8    11    10    9    )
     patch AirOutlet
(    4    5    6    7    )
(    16    17    18    19    )
  patch FuelInlet
    (2 6 5 1)
 patch FuelInlet2
(    9    10    14    13    )
  patch FuelOutlet
(    8    12    15    11    )
(    12    16    19    15    )
patch interface1//block1
(    13    14    18    17    )
patch interface2//block3
(    0    4    7    3    )
   empty back
(    3    7    6    2    )
(    11    15    14    10    )
(    15    19    18    14    )
empty front
(    4    0    1    5    )
(    12    8    9    13    )
(    16    12    13    17    )
edges
mergePatchPairs
Old   April 30, 2020, 10:56
Luis Eduardo
I would say you can try to create a baffle, but I'm not sure if you can use a baffle for what you want, sorry.
Old   April 30, 2020, 13:16
Upuli
Hi
Thank you again. I tried createBaffles. I do not need to have two patches at the interface. I tried to create one baffle after merging the faces in block1 and block3. But it gives two baffles.how can I avoid that?In createBaffles can we edit 'patchPairs' entry to create one baffle face?
I will appreciate your help verymuch.
Following are the entirs in my topoSetDict and createBafflesDict
|  \\    /   O peration     | Version:  4.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
        name    interface1;
        type    cellSet;
        action  new;
        source  zoneToCell;
        sourceInfo
            name block1;
        name    fuinterface1;
        type    faceSet;
        action  new;
        source  cellToFace;
        sourceInfo
            set interface1;
option all;
    name fuinterface1;
    type faceZoneSet;
    action new;
    source setToFaceZone;
    sourceInfo
faceSet fuinterface1;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createBafflesDict;
// Whether to convert internal faces only (so leave boundary faces intact).
// This is only relevant if your face selection type can pick up boundary
// faces.
internalFacesOnly true;
// Baffles to create.
baffles
    baffleFaces
        //- Use predefined faceZone to select faces and orientation.
        type        faceZone;
        zoneName    baffleFaces;
        patchPairs
            type            wall;
            patchFields
                epsilon
             type            zeroGradient;
                k
               type            zeroGradient;
                p
                    type            zeroGradient;
                U
                     type            zeroGradient;
Problem using AMI vinz OpenFOAM Running, Solving & CFD 298 November 13, 2023 08:19
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." lethu OpenFOAM Meshing & Mesh Conversion 1 June 3, 2020 07:49
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 08:00
[mesh manipulation] what if I want twos patches to be merged as one patch and keep as boundary patch nwpukaka OpenFOAM Meshing & Mesh Conversion 2 November 3, 2014 18:25
