[mesh manipulation] Writting mesh connectivity in OpenFOAM |
February 1, 2021, 18:15 |
Pooria
Rep Power: 10 |
I am wondering if anyone knows how to write the mesh connectivity for an isoClip for an example volume fraction between 0-0.5? Any hint is appreciated ) Cheers, /Pooria |
February 1, 2021, 18:28 |
Mark Olesen
Rep Power: 40 |
Needs more description. Are you talking about an iso-surface value, or trying to subset a volume mesh for a particular upper/lower limit and write that out? Even then, you want the outer surface of the mesh, or the enclosed volume mesh? Mesh connectivity in which format?
Lots of things to guess what you mean. |
February 2, 2021, 03:41 |
#3 | |
Pooria
Rep Power: 10 |
Hi, thanks for the help. Yes, as you mentioned, I would like to subset a volume mesh with upper/lower limits including outer surface of the mesh. I have tried this with paraView but I could not get the connectivity. I was able to get the coordinates of the nodes (if I remember correctly) + loads (for example temperature value). The main reason is that I would like to remesh that volume mesh and map the loads into the new mesh. |
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) | Combas | SU2 | 44 | March 12, 2024 00:35 |
[Salome] Script for converting a mesh from Salome-Platform to OpenFOAM | nsf | OpenFOAM Meshing & Mesh Conversion | 86 | February 8, 2023 10:30 |
[Commercial meshers] About the Commercial and Closed Source Meshers discussed here | wyldckat | OpenFOAM Meshing & Mesh Conversion | 3 | July 22, 2020 22:09 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
