[snappyHexMesh] Meshing a simple geometrie fails and I don't know why |
April 26, 2020, 14:08 |
Rep Power: 14 |
I have problems with my first steps with snappyHexMesh after years (learning example). I reduce the case to an simple mesh, but snappyHexMesh fails with meshing. I know the actually blockMesh do not full fit the entry stl geometry. The error with entry stl geometry also occurs and I reduce the problem to an simple cylinder. The meshing fails at the snap step. The result after the undo iteration is added as picture. Also the complete case. What simple fact do I wrong? Thanks, Thomas Link to case file zip archive: https://cloud.thomas-enzinger.de/s/Pt4QCxzZywQk93x (to big with mesh for forum) |
April 28, 2020, 01:45 |
Rep Power: 14 |
solved the problem.
Meshing does ok, only display in paraview needs an step forward. upss ... |
[ANSYS Meshing] Mapped face meshing fails | JorMZ96 | ANSYS Meshing & Geometry | 1 | April 1, 2018 06:56 |
[ANSYS Meshing] Meshing fails, some geometry issues | aop | ANSYS Meshing & Geometry | 4 | June 19, 2017 08:45 |
After meshing, load case file in Fluent fails with "type not interface" | unninss | FLUENT | 0 | August 28, 2015 09:30 |
[Gmsh] Extruded Meshing fails (Linear search / could not find extruded vertex) | Ijazu | OpenFOAM Meshing & Mesh Conversion | 1 | March 18, 2015 07:15 |
meshing on cylinder fails ICEM | potac | ANSYS Meshing & Geometry | 0 | October 25, 2011 05:21 |
