April 1, 2020, 12:11 |
Not extruding boundary layer [SOLVED]
Lorenzo
Rep Power: 7 |
I'm trying to obtain a mesh using snappyHexMesh. I'm using "consolidated" settings (in the sense that these are settings that i often use without any problem).
But in this mesh I needed to create also baffle, therefore I did only one change to the settings: As far as I understood this setting may give some problem with the mesh quality. Indeed I obtained: But over a such a big mesh I hope they don't represent a problem. The real problem is with BL: I really don't understand what I'm doing wrong as I checked the dict many times and the mesh doesn't seem to have evident problems (exept for missing BL). Can someone check if there are evident error in the snappyHexMeshDict I attached? Wherelse can the problem lie? (I also uploaded here the log) Last edited by wilove; April 28, 2020 at 12:12. Reason: I solved my problem |
April 2, 2020, 03:58 |
Rep Power: 7 |
Hi !
Based on your SHMDict, from my point of view, to improve the layers coverage you can try to decrease the resolveFeatureAngle from the castellated phase to 15 degrees. For the snapping phase try to activate multiRegionFeatureSnap. And for the addLayers one, try to put nGrow to 0 because for my cases it has always produced a bad layer coverage onto the geometry. Cheers, |
April 6, 2020, 04:45 |
Lorenzo
Rep Power: 7 |
Thank you for your suggestions!
...but my problems got worse I increased some refinement parameter in addition to the changes you suggested. By doing so my CAD file has proved not to be watertight. Therefore I changed the STL and now it seems to be watertight. Nevertheless snappy gets completrly stuck at the layer addition phase: Code:
Shrinking and layer addition phase ---------------------------------- Using mesh parameters { maxNonOrtho 65; maxBoundarySkewness 15; maxInternalSkewness 2; maxConcave 80; minVol 1e-013; minTetQuality 1e-015; minArea -1; minTwist 0.02; minDeterminant 0.001; minFaceWeight 0.05; minVolRatio 0.01; minTriangleTwist -1; nSmoothScale 4; errorReduction 0.75; } Merging all faces of a cell --------------------------- - which are on the same patch - which make an angle < 180 degrees (cos:-1) - as long as the resulting face doesn't become concave by more than 90 degrees (0=straight, 180=fully concave) Code:
--> FOAM FATAL ERROR: Multiple outside loops:0() From function static Foam::face Foam::combineFaces::getOutsideFace(consPatch&) in file polyTopoChange/polyTopoChange/combineFaces.C at line 442. FOAM parallel run aborting And also with checkMesh it looks like there are no big problems: Code:
[...] Checking geometry... Overall domain bounding box (-35 -0.00524019 -4.98124e-082) (65 50 50) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.31005e-018 4.09243e-015 -5.51466e-016) OK. Max cell openness = 6.28592e-016 OK. Max aspect ratio = 22.7249 OK. Minimum face area = 5.36663e-010. Maximum face area = 1. Face area magnitudes OK. Min volume = 7.06024e-013. Max volume = 1. Total volume = 250000. Cell volumes OK. Mesh non-orthogonality Max: 69.4247 average: 7.13348 Non-orthogonality check OK. Face pyramids OK. ***Max skewness = 14.538, 175 highly skew faces detected which may impair the quality of the results <<Writing 175 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 1 mesh checks. End What can I do next? Since I found few online resouce on that error message I have no clue on how to adress it. |
April 6, 2020, 06:18 |
Rep Power: 7 |
Hi !
Really strange,by looking at this statement : Code:
Merging all faces of a cell --------------------------- - which are on the same patch - which make an angle < 30 degrees (cos:0.866025403784) For me the limit is 180 degrees because there is no improvement above it and because it is related to other function maybe it crashes ? so you can test with featureAngle less or equal to 180. Cheers. Last edited by john myce; April 6, 2020 at 10:21. |
April 6, 2020, 15:55 |
Lorenzo
Rep Power: 7 |
Thank you so much for your speedy reply!
I forgot to mention that I also had alreay lowered featureAngle at 180 deg. In order to try your suggestion I tried to lower it further, setting it at 130 deg. Therefore the "strange" part should now look more standard: Code:
Merging all faces of a cell --------------------------- - which are on the same patch - which make an angle < 130 degrees (cos:-0.642788) - as long as the resulting face doesn't become concave by more than 90 degrees (0=straight, 180=fully concave) I uploaded the full log here and the updated dict. Do you have any further suggestion? P.S.: Do you think this can happen because of the new STL files? I tend to exclude that since the other two phases work well... but I don't know what to think... |
April 7, 2020, 04:11 |
Rep Power: 7 |
To be sure it is the STL file have you done a
checkMesh -allGeometry -allTopology I've just found this thread which is quite interesting for your error if you did not read it yet. It is talking about higher refinement level for edges or better tolerance for your CAD file. Error snappyhexmesh - Multiple outside loops |
April 9, 2020, 17:06 |
Lorenzo
Rep Power: 7 |
Ok in these days our server is being used by someone else but I manage to run at least the checkMesh
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | OpenFOAM for Windows 19.04 (v1) Built by CFD Support, www.cfdsupport.com (based on Symscape). \*---------------------------------------------------------------------------*/ Build : dev-f60147f Exec : C:\OpenFOAM\19.10\cygwin64\opt\OpenFOAM\OpenFOAM-dev\platforms\cygwin64mingw-w64DPInt32Opt\bin\checkMesh.exe -allGeometry -allTopology Date : Apr 09 2020 Time : 18:23:16 Host : "DESKTOP-53KTC8C" PID : 2536 I/O : uncollated Case : C:/OpenFOAM/19.10/Server Dynamis-dev/run/Mesh5 nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Enabling all (cell, face, edge, point) topology checks. Enabling all geometry checks. Time = 0 Mesh stats points: 26317519 faces: 73424513 internal faces: 70626087 cells: 23563099 faces per cell: 6.1134 boundary patches: 23 point zones: 0 face zones: 5 cell zones: 2 Overall number of cells of each type: hexahedra: 21978955 prisms: 320140 wedges: 0 pyramids: 0 tet wedges: 753 tetrahedra: 0 polyhedra: 1263251 Breakdown of polyhedra by number of faces: faces number of cells 4 107773 5 91851 6 246573 7 1786 8 1068 9 598686 10 260 11 373 12 151751 13 14 14 203 15 56330 16 3 17 30 18 6548 21 2 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Number of identical duplicate faces (baffle faces): 108289 <<Number of duplicate (not baffle) faces found: 1640. This might indicate a problem. <<Number of faces with non-consecutive shared points: 3242. This might indicate a problem. <<Writing 224758 faces with non-standard edge connectivity to set edgeFaces <<Writing 36 cells with zero or one non-boundary face to set oneInternalFaceCells <<Writing 392 cells with two non-boundary faces to set twoInternalFacesCells *Number of regions: 37 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" <<Writing region 0 (fully disconnected) with 23563063 cells to cellSet region0 <<Writing region 1 (fully disconnected) with 1 cells to cellSet region1 <<Writing region 2 (fully disconnected) with 1 cells to cellSet region2 <<Writing region 3 (fully disconnected) with 1 cells to cellSet region3 <<Writing region 4 (fully disconnected) with 1 cells to cellSet region4 <<Writing region 5 (fully disconnected) with 1 cells to cellSet region5 <<Writing region 6 (fully disconnected) with 1 cells to cellSet region6 <<Writing region 7 (fully disconnected) with 1 cells to cellSet region7 <<Writing region 8 (fully disconnected) with 1 cells to cellSet region8 <<Writing region 9 (fully disconnected) with 1 cells to cellSet region9 <<Writing region 10 (fully disconnected) with 1 cells to cellSet region10 <<Writing region 11 (fully disconnected) with 1 cells to cellSet region11 <<Writing region 12 (fully disconnected) with 1 cells to cellSet region12 <<Writing region 13 (fully disconnected) with 1 cells to cellSet region13 <<Writing region 14 (fully disconnected) with 1 cells to cellSet region14 <<Writing region 15 (fully disconnected) with 1 cells to cellSet region15 <<Writing region 16 (fully disconnected) with 1 cells to cellSet region16 <<Writing region 17 (fully disconnected) with 1 cells to cellSet region17 <<Writing region 18 (fully disconnected) with 1 cells to cellSet region18 <<Writing region 19 (fully disconnected) with 1 cells to cellSet region19 <<Writing region 20 (fully disconnected) with 1 cells to cellSet region20 <<Writing region 21 (fully disconnected) with 1 cells to cellSet region21 <<Writing region 22 (fully disconnected) with 1 cells to cellSet region22 <<Writing region 23 (fully disconnected) with 1 cells to cellSet region23 <<Writing region 24 (fully disconnected) with 1 cells to cellSet region24 <<Writing region 25 (fully disconnected) with 1 cells to cellSet region25 <<Writing region 26 (fully disconnected) with 1 cells to cellSet region26 <<Writing region 27 (fully disconnected) with 1 cells to cellSet region27 <<Writing region 28 (fully disconnected) with 1 cells to cellSet region28 <<Writing region 29 (fully disconnected) with 1 cells to cellSet region29 <<Writing region 30 (fully disconnected) with 1 cells to cellSet region30 <<Writing region 31 (fully disconnected) with 1 cells to cellSet region31 <<Writing region 32 (fully disconnected) with 1 cells to cellSet region32 <<Writing region 33 (fully disconnected) with 1 cells to cellSet region33 <<Writing region 34 (fully disconnected) with 1 cells to cellSet region34 <<Writing region 35 (fully disconnected) with 1 cells to cellSet region35 <<Writing region 36 (fully disconnected) with 1 cells to cellSet region36 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box side 5000 5151 ok (non-closed singly connected) (-35 50 -2.30247e-082) (65 50 50) symmetry 101167 105508 ok (non-closed singly connected) (-35 0 0) (65 0 50) inlet 2500 2601 ok (non-closed singly connected) (-35 0 -2.30247e-082) (-35 50 50) outlet 2500 2601 ok (non-closed singly connected) (65 0 -2.01398e-205) (65 50 50) ground 168036 170148 ok (non-closed singly connected) (-35 0 -2.30247e-082) (65 50 1.63036e-096) top 5000 5151 ok (non-closed singly connected) (-35 0 50) (65 50 50) DPE_FW 1309273 1371181 ok (non-closed singly connected) (-0.935107 0 0.0580856) (-0.159418 0.738514 0.351191) Radiatori 0 0 ok (empty) Radiatori_slave 0 0 ok (empty) Batterie 0 0 ok (empty) Batterie_slave 0 0 ok (empty) DPE_Telaio 332613 359471 ok (non-closed singly connected) (-0.890818 -0.000595452 0.0276807) (1.98007 0.424718 1.15159) DPE_RW 125824 128733 ok (non-closed singly connected) (1.31592 0 0.514995) (2.03688 0.497021 1.18858) DPE_MW 87578 90895 ok (non-closed singly connected) (0.149646 0.242772 0.0322572) (1.44492 0.697 0.255685) DPE_FWheels 186044 204028 ok (non-closed singly connected) (-0.237524 0.435268 0) (0.237291 0.70396 0.470094) DPE_RWheels 186046 204078 ok (non-closed singly connected) (1.31248 0.435267 0) (1.78729 0.70396 0.470084) DPE_Diffusore 65037 67700 ok (non-closed singly connected) (-0.00282152 0 0.0272791) (2.0339 0.696113 0.258254) Fan_Batterie 77990 82645 ok (non-closed singly connected) (1.89678 0.0868613 0.240428) (1.97834 0.176631 0.287517) Fan_Batterie_slave 79319 82678 ok (non-closed singly connected) (1.89678 0.0868613 0.240428) (1.97834 0.176631 0.287517) Fan_Batterie_Centrale 7519 8427 ok (non-closed singly connected) (1.89678 0 0.250428) (1.97834 0.0484366 0.297517) Fan_Batterie_Centrale_slave 7519 8427 ok (non-closed singly connected) (1.89678 0 0.250428) (1.97834 0.0484366 0.297517) Fan_Radiatori 24492 28238 ok (non-closed singly connected) (1.51297 0.0416183 0.295898) (1.54402 0.13241 0.381188) Fan_Radiatori_slave 24969 28298 ok (non-closed singly connected) (1.51297 0.0416183 0.295898) (1.54402 0.13241 0.381188) Checking geometry... Overall domain bounding box (-35 -0.000595452 -2.30247e-082) (65 50 50) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (3.25169e-020 3.11938e-015 -2.22712e-016) OK. Max cell openness = 4.43716e-016 OK. Max aspect ratio = 15.6226 OK. Minimum face area = 1.31544e-010. Maximum face area = 1. Face area magnitudes OK. Min volume = 6.15459e-013. Max volume = 1. Total volume = 250000. Cell volumes OK. Mesh non-orthogonality Max: 68.5929 average: 7.11855 Non-orthogonality check OK. Face pyramids OK. ***Max skewness = 14.8851, 343 highly skew faces detected which may impair the quality of the results <<Writing 343 skew faces to set skewFaces Coupled point location match (average 0) OK. ***Error in face tets: 6 faces with low quality or negative volume decomposition tets. <<Writing 6 faces with low quality or negative volume decomposition tets to set lowQualityTetFaces *Edges too small, min/max edge length = 4.16334e-017 1, number too small: 122922 <<Writing 122922 points on short edges to set shortEdges <<Writing 122929 near (closer than 0.000122475 apart) points to set nearPoints *There are 27647 faces with concave angles between consecutive edges. Max concave angle = 79.9829 degrees. <<Writing 27647 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.24589 average = 0.999661 *There are 842 faces with ratio between projected and actual area < 0.8 Minimum ratio (minimum flatness, maximum warpage) = 0.24589 <<Writing 842 warped faces to set warpedFaces Cell determinant (wellposedness) : minimum: 0 average: 11.1708 ***Cells with small determinant (< 0.001) found, number of cells: 659 <<Writing 659 under-determined cells to set underdeterminedCells ***Concave cells (using face planes) found, number of cells: 575706 <<Writing 575706 concave cells to set concaveCells Face interpolation weight : minimum: 0.0502973 average: 0.484304 Face interpolation weight check OK. Face volume ratio : minimum: 0.0101874 average: 0.919812 Face volume ratio check OK. Failed 4 mesh checks. End Regarding the topic you linked me: I've already read it, I tried to increase some parameter but, as you can see from the dict, they are already pretty high (therefore I'm already at the limit of server resources). Should I try to increase some setting even further or do you suggest something else? |
April 13, 2020, 04:45 |
Rep Power: 7 |
To be honest I'm running out of ideas.
Maybe changing the decomposition method or drastically the version of OpenFOAM could solve this kind of problem. |
April 14, 2020, 16:43 |
#9 | ||
Lorenzo
Rep Power: 7 |
I'm posting a quick update if someone wants to share any other idea. This is what I've done so far:
Just a final considerations after reading this comment (and in general the whole topic): I think that there is nothing wrong in my STL files nor in my snappyHex settings per se, but probably the combination of both, at high refinements, generates that problem. Unfortunately I cannot share my geometry but I hope that someone has some suggestions on how to avoid that behavior in general. |
April 28, 2020, 12:11 |
#10 | ||
Lorenzo
Rep Power: 7 |
I think I managed to solve my problem. There were mainly 3 problems:
Just a note about this: Quote:
Anyway, thank you again for your help! |
April 28, 2020, 13:49 |
#11 |
Rep Power: 7 |
I'm glad you've solved your problem !
Thanks for sharing this interesting paper. |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
[ICEM] 3D Dynamic Mesh - Boundary layer mesh issues | nathanricks | ANSYS Meshing & Geometry | 0 | September 23, 2015 05:14 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
