[Gmsh] How to draw Quad tree in Gmsh?
Old   January 3, 2016, 12:42
Default How to draw Quad tree in Gmsh?
Hahahahaha
lzk12520 is on a distinguished road
Is there a convenient way to draw quad tree mesh by Gmsh?
I browsed the function buttons and found no relevant option.
My goal is just to install a cylinder surrounded by O-grid into Cartesian grids, as my solver requires low aspect ratio and internal angle of grids. Should I just go to other software like Ansys mesh tools?
Grateful for any suggestion
lzk12520 is offline   Reply With Quote
Old   May 2, 2020, 17:59
ige82157 is on a distinguished road
As far as I can see, there is no quadtree mesh generation algorithm in gmsh https://gmsh.info/doc/texinfo/gmsh.h...ured-algorithm and even the Ansys Help showed 0 results with a search for "quadtree".
ige82157 is offline   Reply With Quote
[Gmsh] Converting gmsh to OpenFoam Friendly OpenFOAM Meshing & Mesh Conversion 3 June 26, 2018 05:46
[Gmsh] Insatlling gmsh from the source code-issue? CFD-Lover OpenFOAM Meshing & Mesh Conversion 20 June 12, 2018 06:39
[Gmsh] Cgns support for gmsh robyTKD OpenFOAM Meshing & Mesh Conversion 1 July 13, 2016 11:27
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
