[snappyHexMesh] cannot find MRF cellZone
Like Tree1Likes
  • 1 Post By linnemann
Old   November 1, 2021, 20:55
Default cannot find MRF cellZone
Muhammad Ahyar
Ahyar is on a distinguished road
hello i'm trying to build a simulation with MRF on it. but when i tried to run the solution command, i've got this error
on the other hand, i've declared the cellZone on my snappyHexMeshDict
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
castellatedMesh true;
snap            true;
addLayers       false;
geometry
    inlet.stl
        type triSurfaceMesh;
        name inlet;
    tank.stl
        name tank;
    impeller
        file "impeller.stl";
    MRF
        type searchableCylinder;
        point1 (0.0 0.0 -0.1);
        point2 (0.0 0.0 0.9);
        radius 0.4;
castellatedMeshControls
    maxLocalCells 100000;
    maxGlobalCells 2000000;
    minRefinementCells 0;
    nCellsBetweenLevels 2;
    maxLoadUnbalance 0.10;
    features
            file "inlet.eMesh";
            level 0;
            file "tank.eMesh";
            level 0;
            file "impeller.eMesh";
            level 0;
    resolveFeatureAngle 30;
    refinementSurfaces
        inlet
            level (0 0);
        tank
            level (0 0);
        impeller
            level (0 0);
        MRF
            level (1 1);
            cellZones cellMRFzone;
            faceZones faceMRFzone;
            cellZoneInside inside;
    refinementRegions
        MRF
            mode inside;
            levels ((1E15 1));
    locationInMesh (0.0 0.0 0.3); // Inside point
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    nSmoothPatch 3;
    tolerance 1.0;
    nSolveIter 300;
    nRelaxIter 10;
    nFeatureSnapIter 10;
    implicitFeatureSnap true;
    explicitFeatureSnap false;
    multiRegionFeatureSnap true;
// Settings for the layer addition.
addLayersControls
    relativeSizes true;
    layers
    expansionRatio 1.0;
    finalLayerThickness 0.3;
    minThickness 0.25;
    nGrow 0;
    featureAngle 30;
    nRelaxIter 5;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedianAxisAngle 90;
    nBufferCellsNoExtrude 0;
    nLayerIter 50;
    nRelaxedIter 20;
meshQualityControls
    #include "meshQualityDict"
    relaxed
        maxNonOrtho 75;
writeFlags
mergeTolerance 1E-6;
and here's the MRFProperties if it matters
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      MRFProperties;
MRFImpeller
    cellZone    cellMRFzone;
    active      yes;
    // Fixed patches (by default they 'move' with the MRF zone)
    nonRotatingPatches ();
    origin    (0.0 0.0 0.0);
    axis      (0 1 0);
    omega     constant 12.56; // ~120 RPM
what should i do?
thanks in advance
Ahyar is offline   Reply With Quote
Old   November 2, 2021, 01:58
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
MRF
     level (1 1);
Should be
MRF
     level (1 1);
     faceZone faceMRFzone;
You can open the case in Paraview after meshing choose to select "Read zones" go to filter "Extract block" and choose the cellzone. That way you can inspect it has been created correctly. checkMesh command will also show if the cellZone has been created.
Ahyar likes this.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   November 2, 2021, 02:28
Muhammad Ahyar
Originally Posted by linnemann View Post
Hi
MRF
     level (1 1);
Should be
MRF
     level (1 1);
thank you so much, it really works
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[swak4Foam] swak4Foam compilation can't find -lOpenFOAM BobR OpenFOAM Community Contributions 4 August 10, 2015 14:49
[foam-extend.org] Installing foam-extend 3.1 on Ubuntu 14.04 stephie OpenFOAM Installation 16 April 23, 2015 16:18
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 06:32
