[Gmsh] Gmsh - unused points error and patches undefined
Old   May 30, 2020, 04:00
Default Gmsh - unused points error and patches undefined
Saideep
Saideep is on a distinguished road
Dear OF users,
I am trying to use GMSH to build the case used in the openfoamwiki.
https://openfoamwiki.net/index.php/2...ial_using_GMSH
This works for me. However, I then tried to change the triangulated mesh into unstructured quadrilaterals using the following procedure:
Tools-> Options -> Mesh -> General -> Subdivision Alg. -> All quads
I have a mesh as shown in the next post with which I am happy. Also all boundary patch are well defined in gmsh.
Then I export in ASCII2 format and run gmshToFoam. I have two issues in here.
1. checkMesh reports one check failed.
 ***Unused points found in the mesh, number unused by faces: 72 number unused by cells: 72
2. The top, bottom, left and right patches are defined though I defined it using physical surfaces in .geo file.
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    back                684      721      ok (non-closed singly connected)
    left                0        0        ok (empty)
    top                 0        0        ok (empty)
    right               0        0        ok (empty)
    bottom              0        0        ok (empty)
    front               684      721      ok (non-closed singly connected)
    defaultFaces        72       144      ok (non-closed singly connected)
Can anyone assist me in finding what am I doing wrong? For reference, I am using the same script mentioned in the above link but using different meshing as I mentioned above.
Thanks.
Last edited by Saideep; May 30, 2020 at 04:05. Reason: Forgot to add image - changed corresponding text
Saideep is offline   Reply With Quote
Old   May 30, 2020, 04:04
Default Desired mesh image
Saideep
Apologies, forgot to add the figure in the above post. The desired mesh for me looks as shown in the attached image.
File Type: jpg Screenshot from 2020-05-30 09-53-15.jpg (151.4 KB, 15 views)
gmsh, mesh 2d to 3d, unstructed mesh
