[blockMesh] Irregularities in the mesh
Like Tree1Likes
  • 1 Post By Ardali
Old   July 2, 2020, 12:17
Default Irregularities in the mesh
milad1990 is on a distinguished road
Hello Every One
I am quit new to OpenFoam and I am trying to make mesh for a geometry based on blockmesh. my Code is working good and mesh "on the surface" looks fine, but when I "slice" the mesh (because its 3D), and use "wireframe "I find some irregularities in mesh like some extra lines. I attached a sample photo. Do you know how can I fix this?
All checkMesh criteria is fine by the way.
Is this Paraview problem or is it really mesh problem? (lnk to photo :https://ibb.co/DMySPgp)
Thank you so much in advance
milad1990 is offline   Reply With Quote
Old   July 2, 2020, 21:09
Ardalan
Ardali is on a distinguished road
You say checkMesh is fine.
How fine is it? All your cells are hexadera? If so, your problem is only representation issue in OF. Dont worry.
Good luck
Ardalan
milad1990 likes this.
Ardali is offline   Reply With Quote
Old   July 3, 2020, 16:09
Hello Ardalan
Thanks for your reply.
My checkMesh says the mesh is fine. By the way I solved the problem. I do not know why, but my domain was from -z to +z and the only slice that had these irregularities was z=0, so I changed the domain to z=0 to z=2*z and now the irregularities are not there any more.
Thanks
Milad
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[snappyHexMesh] High quality mesh for wind in complex urban environment ziboaa OpenFOAM Meshing & Mesh Conversion 1 January 12, 2021 15:33
[ICEM] Bad Quality Hybrid Mesh External Flow tim13 ANSYS Meshing & Geometry 0 March 8, 2020 02:22
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
