[snappyHexMesh] Atmosferic Boundary Layer
Old   June 11, 2020, 04:23
Question Atmosferic Boundary Layer
Alice Zanella
alicezanella is on a distinguished road
Hello there!
I'm currently doing a simulation of a tall building and I have a few doubts, I hope someone can answer them.
  1. I've tried multiple times to do 2 dfferent boundary layers in SHM: one for the ground and one for the building. But it seems that I'm only able to have different layers for them, whereas I would like to completely separate them (like defining different Thickness, Expansion ratio,...). Do you know if it's possible?
  2. What should be the value of the first cell height for the ground? The wind is 10 m/s.
  3. Using a ABL inlet condition, like in the Turbine siting tutorial, should I still be using a boundary layer on the ground?
Thank you in advance.
Alice
alicezanella is offline   Reply With Quote
Old   June 19, 2020, 20:01
Lisandro Maders
Lisandro Maders is on a distinguished road
1. I didn't get exactly what you meant.. do you want or do you NOT want to have different boundary layers for each of them? I would recommend that you have same number of layers if both patches are connected, while it is fine to have different sizes and grow rates for them.
2. Use the CFD-Online calculator for that (https://www.cfd-online.com/Tools/yplus.php) You have to specify the desired y+ value, which depends on the turbulence model and wall function approach used. There are several posts discussing this (a quick search will tell you which y+ size you should use).
3. One thing has nothing related to another. Using the ABL gives you a better inlet profile,but you still need to resolve the boundary layer on every no-slip wall you have in the domain.
Cheers!
Lisandro Maders is offline   Reply With Quote
abl, boundary layer, building aerodynamics, turbine siting
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 10:00
Any formula for approximating the boundary layer thickness around a cylinder? bestniaz Main CFD Forum 0 October 24, 2015 02:00
[ICEM] 3D Dynamic Mesh - Boundary layer mesh issues nathanricks ANSYS Meshing & Geometry 0 September 23, 2015 05:14
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
