[mesh manipulation] HELP!!!mass properties of DynamicMeshDict for 6dof for a boat with passenger
Old   March 16, 2021, 08:24
Post HELP!!!mass properties of DynamicMeshDict for 6dof for a boat with passenger
Deutschland
vava10 is on a distinguished road
Hey,
I have following data:
displacement 77kg (65 passenger+12 kayak boat)
draft T=115.5mm
LCG=2512mm
trim 0deg
V=4.5, 5.5m/s
I have doubts regarding mass properties.
1. Moment of inertia:
I am assuming that the 65 kg is acting at the center of gravity. If so the
moment of inertia does not consider the moment of inertia of the point
mass of 65 kg. It will be the moment of inertia for just the boat. AM I
right?
2. Mass:
In this link https://openfoamwiki.net/index.php/P...dyMotionCoeffs it says " mass
applies to the entire Body". So what is the mass to be used here in my
case???? Mass of boat or sum of both the masses
Thank you in advance
vava10 is offline   Reply With Quote
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
Boat hydrodynamic forces estimation CFD_fan OpenFOAM Running, Solving & CFD 1 December 4, 2019 18:12
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
Adding material to CFX material library marlon CFX 2 October 16, 2016 09:33
error message cuteapathy CFX 14 March 20, 2012 06:45
