[snappyHexMesh] Multiregion mesh - issues at edges
Like Tree3Likes
  • 2 Post By namsivag
  • 1 Post By namsivag
Old   June 29, 2020, 06:56
Default Multiregion mesh - issues at edges
Thangasivam
namsivag is on a distinguished road
Hello all,
I am trying to create fluid and solid meshes (including interface) using snappyHexMesh v1912 for a CHT simulation. I want to study the Heat Transfer between fluid and solid pipe.
I have issues at the highlighted locations in the attached images.
Please give your suggestions to improve. I could not find where I am committing a mistake.
Thanks a lot in advance.
Cheers, Sivam
I codes and values I am using.
BlockMeshDict
scale 1; // convertToMeters does nothing in this case, 0.1 would shrink it by 10x
vertices   // (x y z)
(   -0.0150 -0.0130 -0.0130  )   // in metres // vertex : 0
(   0.0550  -0.0130 -0.0130  )   // in metres // vertex : 1
(   0.0550 0.0130  -0.0130  )   // in metres // vertex : 2
(   -0.0150 0.0130  -0.0130  )   // in metres // vertex : 3
(   -0.0150 -0.0130 0.0130   )   // in metres // vertex : 4
(   0.0550  -0.0130 0.0130   )   // in metres // vertex : 5
(   0.0550 0.0130 0.0130   )   // in metres // vertex : 6
(   -0.0150 0.0130 0.0130   )   // in metres // vertex : 7
blocks
( //                         Divisions
hex (0 1 2 3 4 5 6 7) baseMesh (46 17 17)   simpleGrading (1 1 1)
edges
patches         // Boundaries or faces
mergePatchPairs
topoSetDict
actions
// outside Cylinder Cell set
        name solidCellSet;
        type cellSet;
        action new;
        source surfaceToCell;
        sourceInfo
            file "constant/triSurface/solid.stl";
            // use closed surface inside/outside
            // test (ignores includeCut, outsidePoints)
            useSurfaceOrientation false;
            outsidePoints   ((0.01 0 0));   // definition of outside
            includeCut      true;           // cells cut by surface
            includeInside   false;          // cells not on outside of surf
            includeOutside  false;          // cells on outside of surf
            nearDistance    -1;             // cells with centre near surf (set to -1 if not used)
            curvature       0.9;            // cells within nearDistance and near surf curvature (set to -100 if not used)
// outside Cylinder Zone set
        name    solidZone;
        type    cellZoneSet;
        action  new;
        source  setToCellZone;
        sourceInfo
            set solidCellSet;
// inside Cylinder Cell set
        name fluidCellSet;
        type cellSet;
        action new;
        sourceInfo
            file "./constant/triSurface/fluid.stl";
// inside Cylinder Zone set
        name    fluidZone;
        type    cellZoneSet;
        action  new;
        sourceInfo
            set fluidCellSet;
// combine fluidCell + solidCell set
        name    fluidSolidSet;
        type    cellSet;
        action  new;
        source cellToCell;
        sourceInfo
            set solidCellSet;
            set fluidCellSet;
// invert to get the remaining Set
        name    fluidSolidSet;
        type    cellSet;
        action  invert;
// remaining set to remaining zone
        name    baseZone;
        type    cellZoneSet;
        action  new;
        sourceInfo
            set fluidSolidSet;
// remove the remaining zone
        name    baseZone;
        type    cellZoneSet;
        action  remove;
surfaceFeatureExtractDict
inlet.stl
        extractionMethod    extractFromSurface;
        extractFromSurfaceCoeffs
        {includedAngle   150;}
        writeObj                no;
fluid.stl
        writeObj                no;
fluidOuter.stl
        writeObj                no;
outlet.stl
        writeObj                no;
solid.stl
        writeObj                no;
solidInner.stl
        writeObj                no;
solidOuter.stl
        writeObj                no;
inletPipe.stl
        writeObj                no;
     writeFeatureEdgeMesh    yes;
snappyHexMeshDict
castellatedMesh true;    // make basic mesh ?
snap            true;    // decide to snap back to surface ?
addLayers       true;    // decide to add viscous layers ?
// singleRegionName false;  // Optional
geometry
    fluid.stl     {type triSurfaceMesh; name fluid ; }
    // fluid.stl {type triSurfaceMesh;
    // regions      {fluid {name fluid;}}}
    solid.stl    {type triSurfaceMesh; name solid; }
    // solid.stl {type triSurfaceMesh;
    // regions      {solid {name solid;}}}
    // inlet.stl {type triSurfaceMesh;
    // regions      {inlet {name inlet;}}}
    // outlet.stl {type triSurfaceMesh;
    // regions      {outlet {name outlet;}}}
    // inletPipe.stl {type triSurfaceMesh;
    // regions      {inletPipe {name inletPipe;}}}
    inlet.stl      {type triSurfaceMesh; name inlet     ; }
    outlet.stl     {type triSurfaceMesh; name outlet    ; }
    inletPipe.stl  {type triSurfaceMesh; name inletPipe ; }
    fluidOuter.stl {type triSurfaceMesh; name fluidOuter ; }
    solidInner.stl {type triSurfaceMesh; name solidInner ; }
castellatedMeshControls
    maxLocalCells 10000000;
    maxGlobalCells 20000000;
    minRefinementCells 10;//10;
    maxLoadUnbalance 0.10;//0.10;
    nCellsBetweenLevels 4;//4;
    features // taken from STL from each .eMesh file created by "SurfaceFeatureExtract" command
        {file "fluid.eMesh";      level 2;}
        {file "solid.eMesh";      level 2;}
        {file "outlet.eMesh";     level 2;}
        {file "inlet.eMesh";      level 2;}
        {file "inletPipe.eMesh";  level 2;}
        {file "fluidOuter.eMesh";  level 2;}
        {file "solidInner.eMesh";  level 2;}
    refinementSurfaces // Surface-wise min and max refinement level
        fluid{
            level (2 2); // (min max )
            faceZone fluid;
            cellZone fluid;
            cellZoneInside inside;
        solid{
            level (2 2);
            faceZone solid;
            cellZone solid;
        inlet     { level ( 1 2 ) ; patchInfo { type patch; } }
        outlet    { level ( 1 2 ) ; patchInfo { type patch; } }
        inletPipe { level ( 1 2 ) ; patchInfo { type wall;  } }
        // fluidOuter { level ( 1 2 ) ; patchInfo { type wall;  } }
        // solidInner { level ( 1 2 ) ; patchInfo { type wall;  } }
    resolveFeatureAngle 10;//20;//30;//80
    refinementRegions        // In descending levels of fine-ness
        fluid        {mode inside; levels ((2 1));}
        solid        {mode inside; levels ((2 1));}
    locationInMesh (0.01 0.0 0.0); // in metres
    // locationsInMesh // in metres
    //     (( 0.0  0.0     0.0) inside)
    //     (( 3e-3 6.5e-3  0.0) outside)
    allowFreeStandingZoneFaces true;
snapControls
    nFaceSplitInterval  5;
    nSmoothPatch 5;
    tolerance    1.0;//4.0;
    nSolveIter   60;//300;//60;
    nRelaxIter   5;//10;//5;
    nFeatureSnapIter 10;//15; // default is 10
    implicitFeatureSnap false; // default is false - detects without doing surfaceFeatureExtract
    explicitFeatureSnap true; // default is true
    multiRegionFeatureSnap true; // deafault is false - detects features between multiple surfaces
addLayersControls
    relativeSizes true;
    layers
       fluid_slave
         nSurfaceLayers 3; // was 5
    expansionRatio 1.5;
    finalLayerThickness 5e-3;
    minThickness 5e-4;
    nGrow 0;//was 1;
    featureAngle 110;//85;//30;
    nRelaxIter 5;//3;
    nSmoothSurfaceNormals 4;//1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.2;//0.3;
    minMedianAxisAngle 90;//130;
    nBufferCellsNoExtrude 0;
    nLayerIter 50;
    detectExtrusionIsland true;
meshQualityControls
    maxNonOrtho 65;
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    maxConcave 80;
    minFlatness 0.5;
    minVol 1e-13;
    minArea -1;
    minTwist 0.02;
    minDeterminant 0.001;
    minFaceWeight 0.02;
    minVolRatio 0.01;
    minTetQuality 1e-30;
    minTriangleTwist -1;
    nSmoothScale 4;
    errorReduction 0.75;
debug 0;
writeFlags
    scalarLevels
    layerSets
    layerFields     // write volScalarField for layer coverage
mergeTolerance 1E-6;
namsivag is offline   Reply With Quote
Old   June 29, 2020, 10:53
Rango is on a distinguished road
Just a few observations that may help:
  1. Turn off the "addLayers" option and see if you can get a sharp edge at inlet.
  2. Edit "refinementSurfaces" section to
            fluid{
                level (0 0); // (min max )
                faceZone fluid;
                cellZone fluid;
            solid{
                level (0 0);
                faceZone solid;
                cellZone solid;
            inlet     { level (2 2 ) ; patchInfo { type patch; } }
            outlet    { level ( 2 2 ) ; patchInfo { type patch; } }
    and "refinementRegions" section to
            fluid        {mode inside; levels ((2 2));}
            solid        {mode inside; levels ((2 2));}
  3. Do you need to include "featureEdge (eMesh files)" for every single "stl" file that you have?
  4. Increase "resolveFeatureAngle" to 60.
  5. Turn off "multiRegionFeatureSnap".
Cheers
Rango is offline   Reply With Quote
Old   June 30, 2020, 01:32
Default Wow.. Partial Success
Thangasivam
Dear Rango,
Thanks for the values. Sharp edges are generated at inlet of fluid domain.
Your query :
I thought that "featureEdge (eMesh files)" might improve the meshes at the edges.
Some more help needed.
A. I have some issues at the edges on fluid and solid surfaces at interface starting location. I have highlighted on the attached images.
B. I would like to get rid of the baseMesh interfaces with the solid and fluid surfaces. I have highlighted on the attached images.
Thanks again.
Cheers, Sivam
I am sharing the codes and images.
addLayers       false;    // decide to add viscous layers ?
geometry
    fluid.stl    {type triSurfaceMesh; name fluid; }
        fluid{
            faceZone fluid;
            cellZone fluid;
        solid{
             level (0 0);
            faceZone solid;
            cellZone solid;
        inlet     { level ( 2 2 ) ; patchInfo { type patch; } }
        // inletPipe { level ( 1 2 ) ; patchInfo { type wall;  } }
     resolveFeatureAngle 60;
snapControls
    nSmoothPatch        5;
    tolerance         1.0; // 4.0;
    nSolveIter         60; // 300;
    nRelaxIter          5; // 10;
    nFeatureSnapIter   10; // default is 10
     multiRegionFeatureSnap false;
addLayersControls
    relativeSizes true;
    layers
       fluid_slave
         nSurfaceLayers 3;
    expansionRatio            1.5;
    minThickness             5e-4;
    nGrow                       0;//was 1;
    nRelaxIter                  5;//3;
    nSmoothNormals              3;
    nLayerIter                 50;
meshQualityControls
    maxNonOrtho         65;
    maxConcave          80;
    minFlatness        0.5;
    minVol           1e-13;
    minArea             -1;
    minTwist          0.02;
    minFaceWeight     0.02;
    minVolRatio       0.01;
    nSmoothScale         4;
debug 0;
writeFlags
    scalarLevels
    layerSets
rmaries and altinel like this.
Old   July 16, 2020, 05:34
Default Circular edge is not proper
Thangasivam
Hallo,
I have two surfaces solidHeadBottom (surf-1) and interface2fluid (surf-2).
Mesh at the circular edge is not proper. Please have a look at highlighted areas on the attached images. Could you please help me to cross this issue !!
regards, Sivam
FoamFile{
     version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;}
snap true;
addLayers false;
geometry
    solidHead.stl       {type triSurfaceMesh; name head;  }
    outerSolidHead.stl  {type triSurfaceMesh; name outerSolidHead;}
    solidHeadBottom.stl {type triSurfaceMesh; name solidHeadBottom;}
    interface2fluid.stl {type triSurfaceMesh; name interface2fluid;}
    minRefinementCells  100;
    nCellsBetweenLevels 4; //4;
    features
        // {file "solidHead.eMesh";       level 2;} //2
        {file "outerSolidHead.eMesh";  level 2;} //2
        {file "solidHeadBottom.eMesh"; level 2;} //2
        {file "interface2fluid.eMesh"; level 2;} //2
        head{
            level          (0 1); //0 0
            faceZone       head;
            cellZone       head;
            boundary       internal;
        outerSolidHead  {level (1 2); patchInfo { type wall;}} // 1 1
        solidHeadBottom {level (1 2); patchInfo { type wall;}} // 1 2
        interface2fluid {level (1 2); patchInfo { type wall;}} // 1 2
        head           {mode inside; levels ((1 1));}
    locationInMesh (0.0  0.0  0.071); // Inside point
    allowFreeStandingZoneFaces false;
snapControls
    nSmoothPatch        5;
    nSmoothInternal     $nSmoothPatch;
    tolerance         4.0;
    nSolveIter         300;//60
    nRelaxIter         10;
    implicitFeatureSnap    true; // default is false - detects without doing surfaceFeatureExtract
    explicitFeatureSnap    false;  // default is true
    multiRegionFeatureSnap false; // default is false - detects features between multiple surfaces
addLayersControls
    relativeSizes false;
    layers
        {fluid_slave {nSurfaceLayers 3;}}
    expansionRatio            1.2;
    minThickness             3e-3;
    nGrow                       1;//was 0;
    nRelaxIter                  5;//3;
    nSmoothNormals              3;
    nLayerIter                 50;
    layerTerminationAngle    -180;
meshQualityControls
    maxNonOrtho         180;//65;
    maxConcave           80;
    minFlatness         0.5;
    minVol            1e-13;
    minArea              -1;
    minTwist           0.02;
    minFaceWeight      0.02;
    minVolRatio        0.01;
    nSmoothScale          4;
debug 0;
writeFlags
    scalarLevels
    layerSets
altinel likes this.
cht, chtmultiregion, meshing, shm
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 09:12
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 12:38
[snappyHexMesh] Snappy Hex Mesh - issue with smoothness of the model edges olek.warc OpenFOAM Meshing & Mesh Conversion 1 August 31, 2018 11:31
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
ICEM clustering of mesh points and multiple edges webhaw CFX 4 July 25, 2007 16:29
