[snappyHexMesh] Bad snap on baffle edges
Old   March 19, 2020, 10:00
Default Bad snap on baffle edges
Sita Drost
sita is on a distinguished road
Hi everyone,
I'm really sorry for posting this question again, but my previous post hasn't received any replies so far, and in the meantime I didn't get any further solving my problem myself. I know this looks like a problem that has been solved before, and that there should be answers somewhere on this forum. It's just that I can't find anything specifically on baffles, and the other answers didn't help me so far.
I'm trying to mesh a sail geometry, which I import into snappyHexMesh (OF7) from an stl-file. As the geometry has zero thickness, I'm treating it as a baffle. Even though I'm using explicit feature snapping (and the extracted edges look nice and smooth), in the final mesh the edges of my sail turn out rather badly (see attached images).
Looking through the Snappy log-file (see attached), I do see some warnings, but overall SnappyHexMesh doesn't seem to run into any serious trouble. My experience with SHM is too limited to exactly pin down what's going wrong based on the log-file, unfortunately.
What I've tried so far:
- Refining the background mesh
- Refining the edge mesh
- Refining the surface mesh
- Increasing/decreasing resolveFeatureAngle
- Playing around with settings in snapControls (nSmoothPatch, tolerance, nSolveIter, nRelaxIter, nFeatureSnapIter)
- I came across the tip to relax the mesh quality settings, but I'm unsure which setting(s) would help me here.
None of these settings seem to make much of a difference though. Is there something that I'm missing/doing wrong?
Again, any help would be appreciated!
Many thanks,
Sita
sita is offline   Reply With Quote
Old   October 5, 2020, 19:00
Tanya Peart
Tanya.P is on a distinguished road
Hi Sita, I am having the same issues with infinitely thin sails. Did you end up finding a solution? Thanks
Tanya.P is offline   Reply With Quote
Old   October 6, 2020, 01:17
Sita Drost
Hi Tanya,
Sorry, no, not really. I ended up using a commercial mesher (Hexpress, by Numeca), but that wasn't ideal either to be honest.
In the meantime I've switched jobs, so I haven't spent any more time on this. Hope you'll find a solution soon!
Sita
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 09:12
[snappyHexMesh] Bad snap on baffle edges sita OpenFOAM Meshing & Mesh Conversion 0 March 12, 2020 05:26
SimpleFoam & Theater jipai OpenFOAM Running, Solving & CFD 3 June 18, 2019 10:11
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
