[snappyHexMesh] The overwrite option is not working |
October 9, 2020, 04:37 |
Saverio
Rep Power: 5 |
Hi! I have a very basic question about snappyHexMesh.
I am using OpenFOAM v1912 and I run the command "snappyHexMesh -overwrite 2>&1 | tee log.snappyHexMesh", because I want to overwrite all the mesh files. The problem is that this does not work at all. At the end of the meshing process, I have all the files generated by snappyHexMesh. And this is a big problem for me because If I try to run the FoamToVTK, the checkMesh or the PatchSummary command, they work on all the files and it is very time consuming. Do you have any idea? |
October 14, 2020, 03:59 |
Saverio
Rep Power: 5 |
Well, if someone has the same problem, I found the error in my case. I basically set the mesh debug option equal to 1 in the snappyHexMeshDict file.
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
