[Gmsh] gmshToFoam error depending on export format from Gmsh
Like Tree4Likes
  • 2 Post By lyt7349
  • 2 Post By Andry
Old   November 26, 2018, 10:54
Default gmshToFoam error depending on export format from Gmsh
Cruz Li
lyt7349 is on a distinguished road
Hello guys,
I am new to OpenFOAM and Gmsh. I want to simulate flow around a circular cylinder so I have created a geometry and subsequently a 3D mesh in Gmsh. I am currently using OF 6 and Gmsh 4.0.6 on Ubuntu.
When I used the gmshToFoam command to import my .msh file, I encountered 2 errors. If I exported my mesh as ASCII Version 2 including all elements and parametric coordinates, gmshToFoam spits:
--> FOAM FATAL ERROR:
8 not found in table. Valid entries: 0()
From function const T& Foam::HashTable<T, Key, Hash>::operator[](const Key&) const [with T = int; Key = int; Hash = Foam::Hash<int>]
in file /home/ubuntu/OpenFOAM/OpenFOAM-6/src/OpenFOAM/lnInclude/HashTableI.H at line 134.
FOAM exiting
However, if I If I exported my mesh as ASCII Version 2 including just all elements, gmshToFoam creates the mesh which is viewable with paraFoam, but all my defined physical bodies are not to be seen in the boundary.
Any ideas on why this would happen? Also, I checked multiple tutorial on Youtube and none of them had a similar issue. I would much appreciate your help.
Akshay_11235 and cjmarinj like this.
lyt7349 is offline   Reply With Quote
Old   December 18, 2018, 22:08
Weiliang Zhu
zwlwf is on a distinguished road
Don't know what a wrong you got, I tried with your circularCyl.txt in GMSH 4.0.1, and export to v2 mesh, it is all ok.
zwlwf is offline   Reply With Quote
Old   March 20, 2019, 11:57
Josh Williams
JoshWilliams1996 is on a distinguished road
Did you solve this? I'm having the same issue
JoshWilliams1996 is offline   Reply With Quote
Old   October 15, 2020, 00:06
Default Decision
Andrey
Andry is on a distinguished road
After unchecking the "save all elements" and "save parametric coordinates" when exporting the mesh to the GMSH 2.0 ASCII format, the error disappeared
saidc. and cjmarinj like this.
Andry is offline   Reply With Quote
[Gmsh] New version of gmshToFoam? stootoon OpenFOAM Meshing & Mesh Conversion 7 February 14, 2022 09:01
Issue exporting su2 format from gmsh Gaetano03 SU2 6 September 21, 2018 11:18
Gmsh mesh export gcdiwan Mesh Generation & Pre-Processing 0 October 18, 2015 08:16
Change export node ordering in Gmsh skrishnamoorthy Mesh Generation & Pre-Processing 0 August 11, 2015 20:42
[General] GmshToFoam export with Solution from Matlab Yuki1890 ParaView 0 October 20, 2014 11:03
