[snappyHexMesh] snappyHexMesh - distortions over a complex terrain |
November 8, 2020, 08:27 |
Rep Power: 7 |
I've been trying to mesh a complex terrain topography using snappyHexMesh. Here I attach screengrabs showing the castellated, snapped and layered meshes. As you can see, after snapping, weird triangular anomalies appear between refinement zones. The effect is magnified after adding layers. Could you please have a look and tell me if there's any way to minimize the effect using snappyHexMeshDict controls? I guess that it will significantly distort the simulation. In fact, I spotted these after trying to simulate - the simulation blew up many times, using various discretization schemes, initial boundary conditions of turbulent quantities etc. I guess the blow ups might have been caused by the mesh. I smoothed my .stl geometry in sharp places using meshMixer, and checked it there too. Didn't help. Here I attach the snappyHexMeshDict and logCheckMesh too. Thanks a lot for any help. Screengrabs: https://photos.google.com/share/AF1Q...JjSWV5TmZSa25n Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers true; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { barkley2019.stl { type triSurfaceMesh; name barkley; } refinementBox1 { type searchableBox; min (56 -140 -70); max (175 -41 -30); } refinementBox2 { type searchableBox; min (72 -127 -70); max (157 -57 -45); } }; // Settings for the castellatedMesh generation. castellatedMeshControls // ALL SET TO DEFAULT AS IGLOO TUTORIAL IN OPENFOAM 2.1.0 { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // While refining maximum number of cells per processor. This is basically // the number of cells that fit on a processor. If you choose this too small // it will do just more refinement iterations to obtain a similar mesh. maxLocalCells 1500000;//was1000000 // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 3000000; //was2000000 // The surface refinement loop might spend lots of iterations refining just a // few cells. This setting will cause refinement to stop if <= minimumRefine // are selected for refinement. Note: it will at least do one iteration // (unless the number of cells to refine is 0) minRefinementCells 100; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 1; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( { file "barkley2019.eMesh"; level 2; } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { barkley { // Surface-wise min and max refinement level level (2 2); // } } // Resolve sharp angles resolveFeatureAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { barkley { mode distance; levels ((2 2)(15 1)); } refinementBox1 { mode inside; levels ((1 4)); } refinementBox2 { mode inside; levels ((1 5)); } } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (100 10 -20); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 3; //was 3 //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 1.5; //was 4 //- Number of mesh displacement relaxation iterations. nSolveIter 30; //was 30 //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; //was 5 } // Settings for the layer addition. addLayersControls { relativeSizes true; // Per final patch (so not geometry!) the layer information layers { barkley { nSurfaceLayers 2; } } // Expansion factor for layer mesh expansionRatio 1.5; //was 1 //- Wanted thickness of final added cell layer. If multiple layers // is the // thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. finalLayerThickness 0.4; //- Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.1; //- If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. nGrow 0; // Advanced settings //- When not to extrude surface. 0 is flat surface, 90 is when two faces // make straight angle. featureAngle 60; //was 30 //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 10; //was 20 // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 10; //30 // Smooth layer thickness over surface patches nSmoothThickness 10; // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.3; // Angle used to pick up medial axis points minMedianAxisAngle 90; // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations nLayerIter 50; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { //- Maximum non-orthogonality allowed. Set to 180 to disable. maxNonOrtho 55; //- Max skewness allowed. Set to <0 to disable. maxBoundarySkewness 8; //was 10 maxInternalSkewness 4; //- Max concaveness allowed. Is angle (in degrees) below which concavity // is allowed. 0 is straight face, <0 would be convex face. // Set to 180 to disable. maxConcave 40; //- Minimum projected area v.s. actual area. Set to -1 to disable. minFlatness 0.5; //- Minimum pyramid volume. Is absolute volume of cell pyramid. // Set to very negative number (e.g. -1E30) to disable. minVol 1e-13; //- Minimum quality of the tet formed by the face-centre // and variable base point minimum decomposition triangles and // the cell centre. Set to very negative number (e.g. -1E30) to // disable. // <0 = inside out tet, // 0 = flat tet // 1 = regular tet minTetQuality 1e-30; //- Minimum face area. Set to <0 to disable. minArea -1; //- Minimum face twist. Set to <-1 to disable. dot product of face normal //- and face centre triangles normal minTwist 0.05; //- minimum normalised cell determinant //- 1 = hex, <= 0 = folded or flattened illegal cell minDeterminant 0.001; //- minFaceWeight (0 -> 0.5) minFaceWeight 0.02; //- minVolRatio (0 -> 1) minVolRatio 0.01; //must be >0 for Fluent compatibility minTriangleTwist -1; // Advanced //- Number of error distribution iterations nSmoothScale 4; //- amount to scale back displacement at error points errorReduction 0.75; } // Advanced // Flags for optional output // 0 : only write final meshes // 1 : write intermediate meshes // 2 : write volScalarField with cellLevel for postprocessing // 4 : write current intersections as .obj files debug 0; // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1E-6; // ************************************************************************* // |
November 8, 2020, 08:29 |
logCheckMesh
Rep Power: 7 |
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 6 Exec : checkMesh -allGeometry -allTopology -writeSets vtk Date : Nov 07 2020 Time : 13:59:34 Host : "Node-K" PID : 15749 I/O : uncollated Case : nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Enabling all (cell, face, edge, point) topology checks. Enabling all geometry checks. Reconstructing and writing vtk representation of all faceSets and cellSets. Time = 0 Mesh stats points: 33856 faces: 94500 internal faces: 87750 cells: 30375 faces per cell: 6 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 30375 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box north 675 736 ok (non-closed singly connected) (3 18 -75) (228 18 0) west 675 736 ok (non-closed singly connected) (3 -207 -75) (3 18 0) east 675 736 ok (non-closed singly connected) (228 -207 -75) (228 18 0) south 675 736 ok (non-closed singly connected) (3 -207 -75) (228 -207 0) seabed 2025 2116 ok (non-closed singly connected) (3 -207 -75) (228 18 -75) watersurface 2025 2116 ok (non-closed singly connected) (3 -207 0) (228 18 0) Checking geometry... Overall domain bounding box (3 -207 -75) (228 18 0) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (0 0 0) OK. Max cell openness = 0 OK. Max aspect ratio = 1 OK. Minimum face area = 25. Maximum face area = 25. Face area magnitudes OK. Min volume = 125. Max volume = 125. Total volume = 3796875. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0 OK. Coupled point location match (average 0) OK. Face tets OK. Min/max edge length = 5 5 OK. All angles in faces OK. Face flatness (1 = flat, 0 = butterfly) : min = 1 average = 1 All face flatness OK. Cell determinant (wellposedness) : minimum: 1 average: 7.1385021 Cell determinant check OK. Concave cell check OK. Face interpolation weight : minimum: 0.5 average: 0.5 Face interpolation weight check OK. Face volume ratio : minimum: 1 average: 1 Face volume ratio check OK. Mesh OK. --> FOAM Warning : From function virtual Foam::polyMesh::readUpdateState Foam::polyMesh::readUpdate() in file meshes/polyMesh/polyMeshIO.C at line 209 unexpected consequences. Proceed with care. Time = 0.1 Mesh stats points: 7838622 faces: 22456494 internal faces: 21947138 cells: 7309714 faces per cell: 6.0746059 boundary patches: 7 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 7128224 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 181490 Breakdown of polyhedra by number of faces: faces number of cells 6 9652 8 249 9 162270 10 10 11 10 12 8643 14 1 15 592 18 63 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. <<Writing 14 cells with two non-boundary faces to set twoInternalFacesCells Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box north 1154 1362 ok (non-closed singly connected) (3 18 -58.75) (228 18 0) west 1149 1359 ok (non-closed singly connected) (3 -207 -55) (3 18 0) east 1090 1298 ok (non-closed singly connected) (228 -207 -51.25) (228 18 0) south 1142 1347 ok (non-closed singly connected) (3 -207 -55) (228 -207 0) seabed 0 0 ok (empty) watersurface 2025 2116 ok (non-closed singly connected) (3 -207 0) (228 18 0) barkley 502796 504418 ok (non-closed singly connected) (3 -207 -65) (228 18 -47.5) Checking geometry... Overall domain bounding box (3 -207 -65) (228 18 0) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (0 0 0) OK. Max cell openness = 1.4210855e-16 OK. Max aspect ratio = 1 OK. Minimum face area = 0.024414062. Maximum face area = 25. Face area magnitudes OK. Min volume = 0.0038146973. Max volume = 125. Total volume = 2723160.4. Cell volumes OK. Mesh non-orthogonality Max: 25.239402 average: 4.5571039 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1 OK. Coupled point location match (average 0) OK. Face tets OK. Min/max edge length = 0.15625 5 OK. <<Writing 64 near (closer than 0.00032476915 apart) points to set nearPoints All angles in faces OK. Face flatness (1 = flat, 0 = butterfly) : min = 1 average = 1 All face flatness OK. Cell determinant (wellposedness) : minimum: 0 average: 9.1220592 ***Cells with small determinant (< 0.001) found, number of cells: 22 <<Writing 22 under-determined cells to set underdeterminedCells ***Concave cells (using face planes) found, number of cells: 171838 <<Writing 171838 concave cells to set concaveCells Face interpolation weight : minimum: 0.33333333 average: 0.49448083 Face interpolation weight check OK. Face volume ratio : minimum: 0.125 average: 0.97102435 Face volume ratio check OK. Failed 2 mesh checks. Time = 0.2 Mesh stats points: 7724132 faces: 22297697 internal faces: 21947138 cells: 7309714 faces per cell: 6.0528818 boundary patches: 7 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 7014556 prisms: 40278 wedges: 0 pyramids: 0 tet wedges: 576 tetrahedra: 3 polyhedra: 254301 Breakdown of polyhedra by number of faces: faces number of cells 4 43519 5 29348 6 9818 7 162 8 214 9 161934 10 2 11 5 12 8643 13 1 14 1 15 591 18 63 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. <<Writing 14 cells with two non-boundary faces to set twoInternalFacesCells Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box north 1154 1348 ok (non-closed singly connected) (3 18 -58.44769) (228 18 0) west 1149 1340 ok (non-closed singly connected) (3 -207 -55.591519) (3 18 0) east 1090 1288 ok (non-closed singly connected) (228 -207 -51.631036) (228 18 0) south 1142 1341 ok (non-closed singly connected) (3 -207 -55.061569) (228 -207 0) seabed 0 0 ok (empty) watersurface 2025 2116 ok (non-closed singly connected) (3 -207 0) (228 18 0) barkley 343999 389928 ok (non-closed singly connected) (3 -207 -64.949742) (228 18 -47.551305) Checking geometry... Overall domain bounding box (3 -207 -64.949742) (228 18 0) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-2.7974809e-16 -3.4909474e-17 1.6006563e-14) OK. Max cell openness = 3.2717739e-16 OK. Max aspect ratio = 5.9802703 OK. Minimum face area = 0.0042526317. Maximum face area = 25.101297. Face area magnitudes OK. Min volume = 0.00042588372. Max volume = 125.47902. Total volume = 2722848.4. Cell volumes OK. Mesh non-orthogonality Max: 50.050815 average: 5.1649528 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.6065511 OK. Coupled point location match (average 0) OK. Face tets OK. Min/max edge length = 0.054500217 5.017602 OK. *There are 153 faces with concave angles between consecutive edges. Max concave angle = 39.928199 degrees. <<Writing 153 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.54730354 average = 0.99966578 *There are 13 faces with ratio between projected and actual area < 0.8 Minimum ratio (minimum flatness, maximum warpage) = 0.54730354 <<Writing 13 warped faces to set warpedFaces Cell determinant (wellposedness) : minimum: 1.3552527e-20 average: 9.1241861 ***Cells with small determinant (< 0.001) found, number of cells: 20 <<Writing 20 under-determined cells to set underdeterminedCells ***Concave cells (using face planes) found, number of cells: 154909 <<Writing 154909 concave cells to set concaveCells Face interpolation weight : minimum: 0.11518488 average: 0.49140119 Face interpolation weight check OK. Face volume ratio : minimum: 0.025611981 average: 0.95493121 Face volume ratio check OK. Failed 2 mesh checks. --> FOAM Warning : From function virtual Foam::polyMesh::readUpdateState Foam::polyMesh::readUpdate() in file meshes/polyMesh/polyMeshIO.C at line 209 unexpected consequences. Proceed with care. Time = 0.3 Mesh stats points: 8501455 faces: 24447646 internal faces: 24095816 cells: 7995952 faces per cell: 6.0710047 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 7551543 prisms: 40386 wedges: 0 pyramids: 0 tet wedges: 587 tetrahedra: 4 polyhedra: 403432 Breakdown of polyhedra by number of faces: faces number of cells 4 43607 5 29279 6 9880 7 117302 8 31806 9 162113 10 132 11 4 12 8652 13 1 14 2 15 591 18 63 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box north 1518 1714 ok (non-closed singly connected) (3 18 -58.44769) (228 18 0) west 1511 1704 ok (non-closed singly connected) (3 -207 -55.591519) (3 18 0) east 1454 1654 ok (non-closed singly connected) (228 -207 -51.631036) (228 18 0) south 1506 1707 ok (non-closed singly connected) (3 -207 -55.061569) (228 -207 0) watersurface 2025 2116 ok (non-closed singly connected) (3 -207 0) (228 18 0) barkley 343816 389657 ok (non-closed singly connected) (3 -207 -64.949742) (228 18 -47.551305) Checking geometry... Overall domain bounding box (3 -207 -64.949742) (228 18 0) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.293288e-16 1.3710367e-16 1.561506e-14) OK. Max cell openness = 3.6181098e-16 OK. Max aspect ratio = 18.514103 OK. Minimum face area = 0.00093936106. Maximum face area = 25.598737. Face area magnitudes OK. Min volume = 6.869207e-05. Max volume = 128.3009. Total volume = 2722848.2. Cell volumes OK. Mesh non-orthogonality Max: 54.998438 average: 5.5062416 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.607339 OK. Coupled point location match (average 0) OK. Face tets OK. Min/max edge length = 0.0065951877 5.2278392 OK. *There are 2898 faces with concave angles between consecutive edges. Max concave angle = 39.89553 degrees. <<Writing 2898 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.54069791 average = 0.99967014 *There are 14 faces with ratio between projected and actual area < 0.8 Minimum ratio (minimum flatness, maximum warpage) = 0.54069791 <<Writing 14 warped faces to set warpedFaces Cell determinant (wellposedness) : minimum: 0.0030395989 average: 8.8539072 Cell determinant check OK. ***Concave cells (using face planes) found, number of cells: 128455 <<Writing 128455 concave cells to set concaveCells Face interpolation weight : minimum: 0.029456128 average: 0.48533915 ***Faces with small interpolation weight (< 0.05) found, number of faces: 11 <<Writing 11 faces with low interpolation weights to set lowWeightFaces Face volume ratio : minimum: 0.018587512 average: 0.9327307 Face volume ratio check OK. Failed 2 mesh checks. End |
November 9, 2020, 10:49 |
#3 | |
M
Rep Power: 12 |
Your checkMesh shows some failed mesh metrics, which you should tackle once you have a clear view Run snappy in a mode that gives you output of the mesh metrics, so you can visualize where the bad cells are located and find a way to improve the mesh. |
November 9, 2020, 12:28 |
Rep Power: 7 |
Thanks a lot - makes sense now.
November 9, 2020, 13:16 |
#5 | |
Charles
Rep Power: 9 |
Thanks M. This is very helpful. Can you elaborate a bit more on your comment "Run snappy in a mode"? I'm interested in how to do it.
Charles L. |
November 9, 2020, 15:21 |
#6 | |
Rep Power: 7 |
https://www.youtube.com/watch?v=Ng-flhr_JVM You can write different types of "distorted" concave, skewed etc. cells as .vtk sets. |
snappyhexmesh, terrain |
How to apply variabe roughness, e.g. to complex terrain? | Fridolin | OpenFOAM Running, Solving & CFD | 3 | August 12, 2020 15:09 |
Importing complex terrain | Joăo Silva | FLUENT | 8 | March 27, 2019 14:50 |
[SOWFA] how to use terrainBlockMesher for meshing a complex terrain? | Muhammad Omer Mughal | OpenFOAM Community Contributions | 11 | June 6, 2016 00:39 |
Meshing complex terrain | CFT123 | FLUENT | 0 | March 13, 2015 03:19 |
[ANSYS Meshing] Complex terrain meshing | egge24 | ANSYS Meshing & Geometry | 0 | November 5, 2014 20:05 |
