[snappyHexMesh] motorBike snappyHexMesh -parallel freezes after few iterations
Old   December 14, 2020, 05:49
Default motorBike snappyHexMesh -parallel freezes after few iterations
Kirill
llirik is on a distinguished road
Good day to all
need your help with motorBike OpenFOam benchmark
I have a prototype ARM CPU based cluster
125 separate nodes = 1000 cores in total
Each node hardware configuration:
8cores (Cortex-A53) + 2GB LPDDR3 ram + 16Gb emmc
nodes are interconnected 1Gb ethernet
OpenFoam-v2006
Ubuntu 20.04 aarch64
mpich-3.3.2
GlusterFS mount point for OpenFOAM installation
I checked first on single node: 8cores - everything is OK
but when i start to run on 4nodes/8nodes/16nodes - 32cores/64cores/128cores respectively
I have a problem at this stage:
mpirun -np 32 -hostfile ~/mpi_hosts4 snappyHexMesh -overwrite -parallel
after 2/3 iterations execution freezes, the processor load on the nodes drops from 100% to 70% and next iterations started after an hour or longer
I have no experience using OpenFOAM I am doing research and i need to show as many different tests as possible on my prototype
I will be grateful for any help or advice
llirik is offline   Reply With Quote
Old   December 22, 2020, 18:29
me3840 is on a distinguished road
According to the logfile your cells per refinement level are pretty low. How big is the mesh on 8 cores? Even using all the cells in the last complete level is about 80 cells/core. I don't think the code is going to scale well at that stage.
me3840 is offline   Reply With Quote
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 09:10
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 05:49
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
