[snappyHexMesh] motorBike snappyHexMesh -parallel freezes after few iterations |
December 14, 2020, 05:49 |
Kirill
Good day to all
need your help with motorBike OpenFOam benchmark I have a prototype ARM CPU based cluster 125 separate nodes = 1000 cores in total Each node hardware configuration: 8cores (Cortex-A53) + 2GB LPDDR3 ram + 16Gb emmc nodes are interconnected 1Gb ethernet OpenFoam-v2006 Ubuntu 20.04 aarch64 mpich-3.3.2 GlusterFS mount point for OpenFOAM installation I checked first on single node: 8cores - everything is OK but when i start to run on 4nodes/8nodes/16nodes - 32cores/64cores/128cores respectively I have a problem at this stage: mpirun -np 32 -hostfile ~/mpi_hosts4 snappyHexMesh -overwrite -parallel after 2/3 iterations execution freezes, the processor load on the nodes drops from 100% to 70% and next iterations started after an hour or longer I have no experience using OpenFOAM I am doing research and i need to show as many different tests as possible on my prototype I will be grateful for any help or advice |
December 22, 2020, 18:29 |
Rep Power: 24 |
According to the logfile your cells per refinement level are pretty low. How big is the mesh on 8 cores? Even using all the cells in the last complete level is about 80 cells/core. I don't think the code is going to scale well at that stage.
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
