[Gmsh] How to create one solid per surface when exporting STL files? |
March 22, 2021, 07:57 |
Rep Power: 5 |
Hello!
I create physical surfaces for using them in OpenFOAM later in .geo thanks to: Code:
Merge "fisrt.stl"; Surface Loop(1) = {1}; // first surface* Physical Surface("firstWall") = {1}; Merge "second.stl"; Surface Loop(2) = {2}; // second surface* Physical Surface("secondWall") = {2}; Volume(1) = {1,2}; Physical Volume("Volume") = {1}; Code:
solid firstWall ... endsolid firstWall solid secondWall ... endsolid secondWall Thanks! |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[snappyHexMesh] Add additional boundary layers to complex stl surface | tobijingles | OpenFOAM Meshing & Mesh Conversion | 1 | October 26, 2011 10:45 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
solid edge problem....can you help? | cindy | Main CFD Forum | 3 | April 5, 2004 13:43 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
