[snappyHexMesh] finding problems with emesh file |
March 25, 2021, 20:16 |
piaotaiwei
Hello everyone,I'm trying to export stl files from 3d modeling sofwares.
I've found that when CAD and solidworks export stl files,they'll turn all the coordinates into a positive value,which makes my blockmesh cannot intersect with my trisurface mesh. So I turn to use ug and blender,but then I found another problem.the exported stl files is ok,and the surfaceFeatures option was done successful,but when I do the snappyHexMesh,there comes a fatal error with the emsh file,which CAD and solidworks didn't give. Sorry I cannot upload pictures,but here's the error output: --> FOAM FATAL IO ERROR: "ill defined primitiveEntry starting at keyword 'object' on line 14 and ending at line 14" file: /home/dyfluid/OpenFOAM/dyfluid-8/run/fpso/constant/triSurface/1.eMesh at line 14. From function void Foam:rimitiveEntry::readEntry(const Foam::dictionary&, Foam::Istream&) in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 168. FOAM exiting So does anyone know where the problem is?Is it from the emesh file?Or the stl file?Or from modeling procedure? Thanks all! |
July 8, 2022, 18:39 |
Same problem
Andrew Mills
Rep Power: 6 |
I am having the same issue. if anyone can help would be greatly appreciated!
July 15, 2022, 05:04 |
Rep Power: 3 |
I don't know what you intend to do with emesh but you can extract the emesh from STL files with an OpenFOAM command ( surfaceFeatureExtract ).
You can find more info on this utility in the tutorial of snappyHexMesh here: http://www.wolfdynamics.com/wiki/meshing_OF_SHM.pdf |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
