April 8, 2021, 15:41 |
Skewed cells after snap
Rep Power: 5 |
After I complete SHM, there are 4 cells at the corners of the geometry that are always skewed. I would expect them to be unskewed since blockMesh creates them but for some reason they always show up. Any idea what could be causing this? Thanks P |
April 9, 2021, 01:41 |
M
Rep Power: 12 |
What tells you that they are skewed?
April 9, 2021, 09:20 |
Rep Power: 5 |
Good point.
Maybe my question should have been what causes them to have that shape. The underlying surface mesh? Snap settings? |
April 10, 2021, 12:14 |
M
Rep Power: 12 |
You mean why are they not perfect cubes?
I do not know for sure, but, even if the background mesh covers that geometry 1:1 at that position, I can imagine there are still some minor deviations which causes the smoothing algorithm to slighty shift the nodes around. At least at the right side. Resolution of the used stl file could be a reason too, maybe. At the left side, the first column of cells is obviously thinner than the ones next to it. So, I would guess the initial blockMesh was slightly bigger and then these cells were compressed a bit. However, all these cells are still near perfect, so nothing to worry about. Last edited by AtoHM; April 12, 2021 at 02:09. |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
snappyHexMesh in parallel - FOAM Fatal IO Error | mturcios777 | OpenFOAM Running, Solving & CFD | 4 | August 10, 2012 19:18 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
