[snappyHexMesh] How to import obj terrain file into snappymesh
Old   May 14, 2021, 00:09
Default How to import obj terrain file into snappymesh
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
dear friends:
I need to add the 4 sides and a bottom to this obj terrain file. So we can import it into the snappyMesh.
Could you pleae give me some suggestions,.
ztdep is offline   Reply With Quote
Old   May 15, 2021, 06:35
Michael Alletto
mAlletto will become famous soon enough
You don't need the borders as STL to use snappy. Just make sure that blockMesh cut the terrain and that the rectangular are of blockMesh is not greater than your terrain stl
mAlletto is offline   Reply With Quote
Old   May 15, 2021, 06:37
ztdep's Avatar
p ding
Thanks, but the stl file now is only a surface. it must be and enclosed volume as i know.
Old   May 15, 2021, 06:39
Michael Alletto
No I already made a mesh within a terrain surface like yours. Check the turbine siting tutorial https://develop.openfoam.com/Develop.../turbineSiting
Old   May 15, 2021, 15:32
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Also please check the SnakeRiverCanyon tutorial.
HPE is offline   Reply With Quote
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 16:05
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 03:50
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 35 April 29, 2022 15:35
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
