[mesh manipulation] merge or combine several cellZone |
May 25, 2021, 17:11 |
jackjiang
Rep Power: 6 |
Hi Foamer,
Long story short, I'm making a heat-exchanger mesh with structured and non-structured mesh, so I have to divide them into several groups to mesh them seperately in Salome, it's called submesh. Now I used ideasUnvToFoam to transfer unv file into polymesh, there are for example two different cellzone for shell side. please refer to the attachment, left side Tetrahedron(non-structured mesh) is for one cellzone, right side hexahedron(structured mesh) is for another cellzone. Question is, how to merge/combine these two cellzone together to make one cellzone since they should be the single cellzone for heat exchanger shell side fluid. Really appreciate any idea or hint, maybe do something in Toposet, Salome, even gmesh? I could send my unv&polymesh through email if needed... Thanks! BR/Jack |
January 19, 2023, 05:02 |
Shenhui Ruan
Rep Power: 4 |
Hi jackjiang,
I know a 2 steps method with topoSet 1-using "zoneToCell", creating a cellset containing the 2 cellzone. it means the source in topoSet is the 2 cellzone. https://www.openfoam.com/documentati...oneToCell.html 2-using "setToCellZone", changing the cellset containing the 2 cellzone to a cellzone. https://www.openfoam.com/documentati...oCellZone.html Shenhui Ruan, Best regards! |
mesh, salome |
[snappyHexMesh] Boundary layers across rotorDisk cellZone | vLhomme | OpenFOAM Meshing & Mesh Conversion | 3 | April 7, 2021 04:46 |
[snappyHexMesh] Error when setting locationsInMesh | elonesampaio | OpenFOAM Meshing & Mesh Conversion | 1 | April 3, 2021 17:44 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM Running, Solving & CFD | 6 | January 25, 2019 00:11 |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM | 0 | January 16, 2019 01:16 |
