[snappyHexMesh] snappyHexMesh addLayers questions |
May 21, 2021, 16:24 |
Lukas Kutej
Rep Power: 10 |
Hello, I am trying to mesh a channel by snappyHexMesh for LES without wall function.
To capture small eddies near to the wall, which is crucial to prevent the velocity overshoot in velocity profile (caused by superstreaks) I am refining the mesh in near wall region in all three directions. That's the idea... But when I go with delta_x+, delta_y+ and delta_z+ to 1, then I go crazy with total # of cells... 1.) So I am happy with corser cells but I WANT TO SPLIT the first cell layer in normal direction... How can I do this? To remain whole mesh and just split the first layer? My idea was, to define boundary layer of two layers of total hight same als the first cell layer. But I have this feeling that snappy shift some cell layers over the boundary layer when I create them. You can see that behaviour on my pictures. (oh...on the picture there is the boundary layer made by two layers with expansionRation 2 - this was my best solution to keep the cell hight in first two layers) 2.) How can I prevent to colapse the boundary layer in the corner please? I set featureAngle 180 but I am not happy :-) |
May 21, 2021, 17:48 |
Lukas Kutej
Rep Power: 10 |
...could I have a additional question: is it possible to generate a boundary layer higher than one cell layer please? Let's say two times higher with 6 layers?
So higher than this one on the picture... |
May 24, 2021, 17:52 |
Lukas Kutej
Rep Power: 10 |
I made some progress...
the key is to switch from medial-axis algorithm (default) to meshShrinker: // maxThicknessToMedialRatio 0.3; //medial-axis // minMedialAxisAngle 90; //medial-axis meshShrinker displacementMotionSolver; solver displacementLaplacian; displacementLaplacianCoeffs { diffusivity quadratic inverseDistance (wall1 wall2 etc); } additional: - in fvSolution: solvers { cellDisplacement { solver GAMG; smoother GaussSeidel; tolerance 1e-7; relTol 0.01; } } - in fvSchemes: gradSchemes { default Gauss linear; } laplacianSchemes { laplacian(diffusivity,cellDisplacement) Gauss linear corrected; } But could someone help me please how can I prevent collapsing of the boundary layer in the corner? I would really appreciate that... :-) |
May 24, 2021, 17:54 |
Lukas Kutej
Rep Power: 10 |
see picture...
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
[snappyHexMesh] Mesh elements disappearing after processing snappyHexMesh (addLayers) | maryCFD | OpenFOAM Meshing & Mesh Conversion | 5 | December 8, 2016 13:33 |
[snappyHexMesh] some basic questions about snappyhexmesh | fatemehfarshi62 | OpenFOAM Meshing & Mesh Conversion | 0 | January 3, 2016 03:29 |
[snappyHexMesh] snappyHexMesh runs endless - I need general advise | TeresaT | OpenFOAM Meshing & Mesh Conversion | 5 | November 17, 2015 02:50 |
[snappyHexMesh] OFW10 snappyHexMesh Training Session Questions (follow up) | chegdan | OpenFOAM Meshing & Mesh Conversion | 3 | July 20, 2015 11:10 |
