[snappyHexMesh] Is is possible to snap geometries from a mesh that doesn't satisfy 2:1 transition?
Old   June 6, 2021, 14:27
Default Is is possible to snap geometries from a mesh that doesn't satisfy 2:1 transition?
chen112p's Avatar
Junting Chen
chen112p is on a distinguished road
Hello all, this is what I am trying to do:
1. blockMesh
2. snapyHexMesh with only "castellation" on (for later refineMesh purpose)
3. run simpleFoam for n iterations, get some field values
4. topoSet grabbing cells based on one of the field value
5. refineMesh applied to cells grabed from topoSet (i dont think refineMesh works well on cell type other than hex, or i didnt do it right)
6. snappyHexMesh snap geometry edges, maybe add layers too.
When running snappyHexMesh in step 6, system tells me:
Celllevel does not satisfy 2:1 constraint
it is reasonable.. because refineMesh for sure will mess up refinement level transition.. but I also wondering if the requirement of smooth transition is required in the snapping stage. If not, is there a way to bypass it?
Thanks in advance,
Junting Chen
chen112p is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[snappyHexMesh] High quality mesh for wind in complex urban environment ziboaa OpenFOAM Meshing & Mesh Conversion 1 January 12, 2021 15:33
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
