[snappyHexMesh] SnappyHexMesh (surfaceFeatures) |
February 13, 2023, 01:23 |
Haider
Rep Power: 3 |
Hello everyone,
I hope you are all in good health. I am using Ubuntu 22.04 and OpenFoam10. When I use the command "surfaceFeatures" then the following error I am facing can be seen in the attached picture. Can anyone guide me to resolve this problem? Thank you! |
February 13, 2023, 05:09 |
M
Rep Power: 12 |
Does the file exist?
February 14, 2023, 00:09 |
Haider
Rep Power: 3 |
February 13, 2023, 05:11 |
Yann
Rep Power: 26 |
Do you have a surfaceFeaturesDict file in the system directory? Regards, Yann EDIT: AtoHM is faster |
February 14, 2023, 00:11 |
Haider
Rep Power: 3 |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
