August 18, 2021, 04:10 |
Weird behaviour of spline-edge
Hallo all,
I am trying to create a cylindrical, twisted block mesh. The cylindrical part is no issue, the "arc" edge definition works like a charm. (Yes, it is intentional that the mesh - at the moment - looks like that) If I add a twist to the last mesh section of pi/2 (think: align mesh cells with the wake of a propeller blade) the result looks like this: Again, this looks as expected, the "weird curved shape" (is there an "official" term?) results from the start and end plane being connected by a line through two points, there is no way it can know how to twist. Edit: While this post was in moderation I solved the spline issue (something to do with something 60 cm in front of the monitor). Nevertheless: I add splines following a helix around the cylinder, and the points indeed lie on the cylinder surface. The resulting blockMesh on the other hand has a weird wobble overlaid on the surface (if you look a a projected view). Regardless of the number of spline support points and number of block divisions, there still seems to be a more or less periodic diameter change going on. Have any of you encountered the same behaviour? Last edited by lhiapgpeonk; August 20, 2021 at 03:22. |
September 22, 2021, 05:12 |
I was able to resolve my problem by projecting edges and faces to a geometry (a cylinder for example) inside of blockMesh.
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
airfoil edge via spline in OpenFOAM v6 | jkampman | Mesh Generation & Pre-Processing | 0 | November 26, 2018 05:19 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
