November 30, 2021, 08:51 |
stl does not appear
Gabriel
Rep Power: 4 |
Hi, I run snappyHexMesh but stl does not appear.
Steps that i have done: 1. create stl in salome 2. put it in geometry folder 3. modify blockmesh for a smaller domain 4. modify surfacefeaturesdict and snappyhexmeshdict with name of the stl 5. run blockmesh, surfacefeatures and shm. Im using openfoam v9, modified windaroundbuildings tutorial i attach relevant files: surfacesfeaturesdict Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; object surfaceFeaturesDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // surfaces ("cylinder.stl"); #includeEtc "caseDicts/surface/surfaceFeaturesDict.cfg" // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #includeEtc "caseDicts/mesh/generation/snappyHexMeshDict.cfg" castellatedMesh on; snap on; addLayers off; geometry { cylinder { type triSurfaceMesh; file "cylinder.stl"; } /* refinementBox { type searchableBox; min ( 0 0 0); max (250 180 90); }*/ }; castellatedMeshControls { features ( { file "cylinder.eMesh"; level 1; } ); refinementSurfaces { buildings { level (3 3); patchInfo { type wall; } } } refinementRegions { refinementBox { mode inside; level 2; } } locationInMesh (1 1 1); } snapControls { explicitFeatureSnap true; implicitFeatureSnap false; } addLayersControls { layers { "CAD.*" { nSurfaceLayers 2; } } relativeSizes true; expansionRatio 1.2; finalLayerThickness 0.5; minThickness 1e-3; } meshQualityControls {} writeFlags ( // scalarLevels // layerSets // layerFields ); mergeTolerance 1e-6; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // backgroundMesh { xMin -10;//-20; // L = 350 xMax 10;//330; yMin -10;//-50; // L = 280 yMax 10;//230; zMin -10; zMax 10;//140; xCells 10;//25; yCells 10;//20; zCells 10;//10; } convertToMeters 1; vertices ( ($!backgroundMesh/xMin $!backgroundMesh/yMin $!backgroundMesh/zMin) ($!backgroundMesh/xMax $!backgroundMesh/yMin $!backgroundMesh/zMin) ($!backgroundMesh/xMax $!backgroundMesh/yMax $!backgroundMesh/zMin) ($!backgroundMesh/xMin $!backgroundMesh/yMax $!backgroundMesh/zMin) ($!backgroundMesh/xMin $!backgroundMesh/yMin $!backgroundMesh/zMax) ($!backgroundMesh/xMax $!backgroundMesh/yMin $!backgroundMesh/zMax) ($!backgroundMesh/xMax $!backgroundMesh/yMax $!backgroundMesh/zMax) ($!backgroundMesh/xMin $!backgroundMesh/yMax $!backgroundMesh/zMax) ); blocks ( hex (0 1 2 3 4 5 6 7) ( $!backgroundMesh/xCells $!backgroundMesh/yCells $!backgroundMesh/zCells ) simpleGrading (1 1 1) ); boundary ( inlet { type patch; faces ( (0 3 7 4) ); } outlet { type patch; faces ( (1 5 6 2) ); } ground { type wall; faces ( (0 1 2 3) ); } frontAndBack { type symmetry; faces ( (0 4 5 1) (3 2 6 7) (4 7 6 5) ); } ); // ************************************************************************* // |
November 30, 2021, 12:44 |
matej forman
Rep Power: 17 |
In your snappyHexMeshDict in section refinementSurfaces - you forgot to update the surface names. your stl is called cylinder, but you are having buildings surface name in refinementSurfaces.
Make this consistent and things should be better. |
November 30, 2021, 15:30 |
Gabriel
Rep Power: 4 |
wow it works!, thank you
[mesh manipulation] How to split stl file? | sunagra27 | OpenFOAM Meshing & Mesh Conversion | 5 | March 18, 2021 11:00 |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[ICEM] STL file! How is it useful? | bidi | ANSYS Meshing & Geometry | 0 | December 26, 2016 21:33 |
[ICEM] Work with imported STL geometry | KateEisenhower | ANSYS Meshing & Geometry | 2 | July 9, 2015 10:46 |
[snappyHexMesh] Experimentally obtained STL file for internal Flow SnappyHexMesh | Irish09 | OpenFOAM Meshing & Mesh Conversion | 9 | April 7, 2012 08:50 |
