January 9, 2022, 12:58 |
Avoid mesh "bumping"
Miguel Hernandez
Rep Power: 5 |
Hello to everyone,
In an interfoam simulation I'm in-countering some stability problems, my idea is that these problems are due to the poor mesh. But, what I'd like to ask is normal to have a sort of rough surface, to be more specific: in postprocesing (paraview) I checked the results using a clip over a scalar (alpha.water) equal to 0.5 in order to visualize only water; the results are shown in the figure below. Is normal to have this kind of "rough" - unnaturally regular - pattern on the water surface? How can I avoid it? Thanks... Miguel Schermata 2022-01-09 alle 18.52.24.jpg |
January 19, 2022, 09:35 |
Miguel Hernandez
Rep Power: 5 |
Can this be related to some paraview's graphical issues?
January 21, 2022, 01:41 |
M
Rep Power: 12 |
Would you show your mesh resolution/type?
Using point data in Paraview can smooth out a bit, don't know what you are using here. |
January 31, 2022, 05:50 |
Miguel Hernandez
Rep Power: 5 |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
GeometricField -> mesh() Function | Tobi | OpenFOAM Programming & Development | 10 | November 19, 2020 11:33 |
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) | shubham jain | ANSYS Meshing & Geometry | 1 | April 10, 2017 05:03 |
[snappyHexMesh] Snappyhex mesh: poor inlet mesh | Swagga5aur | OpenFOAM Meshing & Mesh Conversion | 1 | December 3, 2016 16:59 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
