[snappyHexMesh] Error in the refinement region generation |
March 2, 2022, 17:45 |
Rahul S Parameswaran
Hello!
I have tried to use snappyHexMesh to generate 2 refinement zones (cuboids) around my object with different refinement levels. After generating the castellated mesh, my refinement regions do not match with the refinement region I have specified on my code. Kindly find the images of the error and my code attached. Let me know your thoughts Thank you Rahul Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers false; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { sphere35cmswv2.stl { type triSurfaceMesh; name stl1; //patch name } refinementBox1 { type searchableBox; min (-0.4875 -0.4375 -0.4375); //(-0.4875 -0.6125 -0.6125); //(-1.0 -0.7 0.0); max (3.4625 0.7875 0.7875); //(1.4875 0.7875 0.7875); //(1.4875 0.6125 0.6125); //( 8.0 0.7 2.5); } refinementBox2 { type searchableBox; min (-0.875 -1.05 -1.05); //(-0.875 -1.225 -1.225); //(-1.0 -0.7 0.0); max (6.825 1.4 1.4); //(2.975 1.4 1.4); //(2.975 1.225 1.225); //( 8.0 0.7 2.5); } }; // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 100000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 2000000; // The surface refinement loop might spend lots of iterations refining just a // few cells. This setting will cause refinement to stop if <= minimumRefine // are selected for refinement. Note: it will at least do one iteration // (unless the number of cells to refine is 0) minRefinementCells 10; // Allow a certain level of imbalance during refining // (since balancing is quite expensive) // Expressed as fraction of perfect balance (= overall number of cells / // nProcs). 0=balance always. maxLoadUnbalance 0.10; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 3; //3; //10; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( { file "sphere35cmswv2.eMesh"; level 3; } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { stl1 { // Surface-wise min and max refinement level level (2 2); //(2 3); //(5 6); // Optional specification of patch type (default is wall). No // constraint types (cyclic, symmetry) etc. are allowed. patchInfo { type wall; inGroups (stl1); } } } // Resolve sharp angles resolveFeatureAngle 30; planarAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { refinementBox1 { mode inside; levels ((3 3));//((3 3)); //((3 2)); //((1E15 4)); } refinementBox2 { mode inside; levels ((2 2)); //((3 2)); //((1E15 4)); } } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (1 2 2); //(3.0001 3.0001 0.43); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 3; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 2.0; //- Number of mesh displacement relaxation iterations. nSolveIter 30; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Feature snapping //- Number of feature edge snapping iterations. // Leave out altogether to disable. nFeatureSnapIter 10; //- Detect (geometric only) features by sampling the surface // (default=false). implicitFeatureSnap true; //false; //- Use castellatedMeshControls::features (default = true) explicitFeatureSnap true; //- Detect points on multiple surfaces (only for explicitFeatureSnap) multiRegionFeatureSnap false; } // Settings for the layer addition. addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes true; // Per final patch (so not geometry!) the layer information layers { "(stl1|sphere35cmswv2).*" { nSurfaceLayers 10; //1; } } expansionRatio 1.0; finalLayerThickness 0.1; finalLayerRatio 0.01; minThickness 0.002; nGrow 0; featureAngle 30; nRelaxIter 10; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 40; nBufferCellsNoExtrude 0; nLayerIter 100; nRelaxedIter 20; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { #include "meshQualityDict" } // Advanced // Write flags writeFlags ( scalarLevels layerSets layerFields // write volScalarField for layer coverage ); // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; /*vertices ( (-5 -4 0) (15 -4 0) (15 4 0) (-5 4 0) (-5 -4 8) (15 -4 8) (15 4 8) (-5 4 8) ); */ xmin -2.1; //-2.275; xmax 17.5; //8.75; //8.575; ymin -3.15; //-3.325; ymax 3.5; //3.325; zmin -3.15; //-3.325; zmax 3.5; //3.325; deltax 0.1; deltay 0.1; deltaz 0.1; lnx #calc "abs(($xmax) - ($xmin))"; lny #calc "abs(($ymax) - ($ymin))"; lnz #calc "abs(($zmax) - ($zmin))"; xcells #calc "round(abs(($lnx)/$deltax))"; ycells #calc "round(abs(($lny)/$deltay))"; zcells #calc "round(abs(($lnz)/$deltaz))"; vertices ( //BLOCK1 ($xmin $ymin $zmin) //0 ($xmax $ymin $zmin) //1 ($xmax $ymax $zmin) //2 ($xmin $ymax $zmin) //3 ($xmin $ymin $zmax) //4 ($xmax $ymin $zmax) //5 ($xmax $ymax $zmax) //6 ($xmin $ymax $zmax) //7 ); blocks ( hex (0 1 2 3 4 5 6 7) ($xcells $ycells $zcells) simpleGrading (1 1 1) ); edges ( ); boundary ( frontAndBack { type wall; faces ( (3 7 6 2) (1 5 4 0) ); } inlet { type patch; faces ( (0 4 7 3) ); } outlet { type patch; faces ( (2 6 5 1) ); } leftWall //lowerWall { type wall; faces ( (0 3 2 1) ); } rightWall //upperWall { type wall; faces ( (4 5 6 7) ); } ); // ************************************************************************* // |
March 3, 2022, 03:03 |
M
Rep Power: 12 |
Hi, would you add in the image what you expect the regions to look like? Are the levels wrong or the spatial covering?
Tip: its good practise to not use locationInMesh with integers as input. If that coordinate hits a node on the generated mesh, it can cause problems in snappy. Better to use slightly off floats like shown in your commented part of that line. Although this is probably not the reason for your problem here. |
March 3, 2022, 16:47 |
#3 | |
Kindly find the attached image according to which I require the mesh to be. I generated that mesh without the addition of layers but with the combination of refinement layers as ((3 3)) and ((2 2)) for refinementBox1 and refinementBox 2 respectively but the refinementBox sizes are smaller than the ones that I have mentioned in the code in my post. I also tried to change the locationInMesh with integers but the output still remains the same. Let me know if any other suggestions would work. Thank you Rahul |
castellatedmeshcontrols, refinement regions, snappyhexmesh 3d |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 10:11 |
[snappyHexMesh] sHM refinement away from surface | nholt | OpenFOAM Meshing & Mesh Conversion | 1 | June 14, 2016 14:36 |
[snappyHexMesh] snappyHexMesh refinement regions ignored | guitarbren | OpenFOAM Meshing & Mesh Conversion | 2 | April 9, 2013 03:59 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
