May 23, 2022, 13:54 |
Meshing cylinder in salome
Rep Power: 4 |
Hello to all,
I would like to make a cylinder with a square on top. Image bellow. https://i.ibb.co/7GTcC5q/a.png Is there any way to control the amount of elements across the thickness of the cylinder and the cube? The approach is to create a plane to separate the objects. Now I need a way to control the amount of elements across the thickness. Has anyone faced a similar issue? I could get the 10 elements across the thickness by setting the maximum size to a 1/10 of the thickness value but this will result in a huge mesh... Best Regards |
May 25, 2022, 07:08 |
Niels Nielsen
Rep Power: 27 |
See the attached Salome dump.
See if you can work through what it does.
Linnemann PS. I do not do personal support, so please post in the forums. |
[ICEM] Meshing of a cylinder containing a small hole on one face | Giova82 | ANSYS Meshing & Geometry | 1 | August 12, 2015 06:49 |
Cylinder Intake Meshing | dbagtbag | CFX | 11 | July 30, 2015 07:59 |
[snappyHexMesh] SnappyHexMesh Meshing inside a cylinder | nammari | OpenFOAM Meshing & Mesh Conversion | 5 | March 11, 2011 19:49 |
2D planar cylinder meshing problem | saisanthoshm88 | ANSYS Meshing & Geometry | 15 | December 27, 2010 11:14 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
