[snappyHexMesh] snappyhexmesh does not remove cells |
May 31, 2022, 09:03 |
Muhammad Ahyar
Rep Power: 6 |
I want to generate mesh from this geometry that i create using freecad and its format is .obj
but when i tried to generate using snappyhexmesh utility, the mesh doesn't come out as i expected, the background mesh outside the geometry still exists and are not removed by snappyhexmesh. this is my snappyHexMeshDict Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // castellatedMesh true; snap true; addLayers false; geometry { inlet.obj { type triSurfaceMesh; name inlet; } outletBawah.obj { type triSurfaceMesh; name outlet; } outletAtas.obj { type triSurfaceMesh; name outlet; } walls.obj { type triSurfaceMesh; name walls; } } castellatedMeshControls { maxLocalCells 1000000; maxGlobalCells 2000000; minRefinementCells 0; nCellsBetweenLevels 2; maxLoadUnbalance 0.10; features ( { file "inlet.eMesh"; level 3; } { file "walls.eMesh"; level 1; } { file "outletBawah.eMesh"; level 0; } { file "outletAtas.eMesh"; level 0; } ); resolveFeatureAngle 30; refinementSurfaces { inlet { level (2 2); } walls { level (1 1); } outletBawah { level (0 0); } outletAtas { level (0 0); } } refinementRegions { } locationInMesh (0.0 0.0 0.0); // Inside point allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { nSmoothPatch 3; tolerance 1.0; nSolveIter 300; nRelaxIter 10; nFeatureSnapIter 10; implicitFeatureSnap true; explicitFeatureSnap false; multiRegionFeatureSnap true; } // Settings for the layer addition. addLayersControls { relativeSizes true; layers { } expansionRatio 1.0; finalLayerThickness 0.3; minThickness 0.25; nGrow 0; featureAngle 30; nRelaxIter 5; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 90; nBufferCellsNoExtrude 0; nLayerIter 50; nRelaxedIter 20; } meshQualityControls { #include "meshQualityDict" relaxed { maxNonOrtho 150; } } writeFlags ( ); mergeTolerance 1E-6; // ************************************************************************* // and below is my case tankiFlotation.zip |
June 2, 2022, 01:00 |
M
Rep Power: 12 |
At first look I am not sure, if thats whats happening. Maybe, rather than removing the outside part, snappy removed the inner part (hard to tell from the images). Review the position of locationInMesh. It should be inside your geometry and tell snappy what part to keep or remove. If it coincides with a face or node, it might cause confusion for snappy, try moving it well within your geomety.
June 2, 2022, 23:20 |
#3 | |
Muhammad Ahyar
Rep Power: 6 |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
chtMultiRegionFoam speed up | qwertz | OpenFOAM Running, Solving & CFD | 8 | September 18, 2021 06:16 |
[snappyHexMesh] snappyHexMesh stuck when snap is turned on | yukuns | OpenFOAM Meshing & Mesh Conversion | 3 | February 2, 2021 13:05 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
