[snappyHexMesh] Deformed features arround the refined area |
June 1, 2022, 18:47 |
Christian Pinzón
Rep Power: 4 |
I am meshing a jet in crossflow domain, but in the plate zone snappyhexmesh make an unexplained grobe in the base arround the main channel (img1), and also in the corner borders in top an plate the meshing is incomplete (img2).
I have tried switching implicitFeatureSnap, explicitFeatureSnap, and incresing and decreasing tolerance, increasing different levels, as is explained in other posts, but the outcome is similar. Could you give me any suggestion, thanks sHM code: Code:
geometry { geome { type triSurfaceMesh; file "geome.stl"; } inlet_channel { type triSurfaceMesh; file "inlet_channel.stl"; } sides { type triSurfaceMesh; file "sides.stl"; } out { type triSurfaceMesh; file "out.stl"; } top { type triSurfaceMesh; file "top.stl"; } channel { type triSurfaceMesh; file "channel.stl"; } plate { type triSurfaceMesh; file "plate.stl"; } inlet { type triSurfaceMesh; file "inlet.stl"; } }; castellatedMeshControls { maxLocalCells 2000000; maxGlobalCells 2000000; minRefinementCells 20;// Motorbike 10 maxLoadUnbalance 0.10; // nCellsBetweenLevels 2; // buffer cells. resolveFeatureAngle 30;// 60? gapLevelIncrement 1; features // taken from STL from each .eMesh file created by "SurfaceFeatureExtract" command ( /*{ file "geome.eMesh"; levels ((0.03 3)); }*/ {file "inlet.eMesh"; level 1;} {file "out.eMesh"; level 1;} {file "plate.eMesh"; level 3;} // level3 {file "top.eMesh"; level 0;} {file "sides.eMesh"; level 0;} {file "inlet_channel.eMesh"; level 2;} {file "channel.eMesh"; level 2;} ); refinementSurfaces // Surface-wise min and max refinement level { inlet {level (0 0);} out {level (0 0);} plate {level (2 3);} //(3 3) channel {level (2 3);} sides {level (0 0);} top {level (0 0);} inlet_channel {level (2 2);} } refinementRegions { channel { // refinement level 5 within 1.0 m mode distance; // refinement level 3 within 2.0 m levels ((0.005 2)); // levels must be ordered nearest first } inlet_channel { mode distance; levels ((0.009 2)); } } locationInMesh (1e-5 1e-5 1e-5); // Offset from (0 0 0) to avoid allowFreeStandingZoneFaces false; } snapControls { implicitFeatureSnap true; explicitFeatureSnap false; nSmoothPatch 6; nSmoothInternal $nSmoothPatch; tolerance 2.0; nSolveIter 90; nRelaxIter 15; // Feature snapping //- Number of feature edge snapping iterations. // Leave out altogether to disable. nFeatureSnapIter 10; detectBaffles true; multiRegionFeatureSnap false; } Code:
backgroundMesh { xMin -0.210; xMax 0.610; yMin -0.120; yMax 0.130; zMin -0.021; zMax 0.021; xCells 240; yCells 70; zCells 13; /* xCells 200; yCells 60; zCells 10;*/ } convertToMeters 1; vertices ( ($:backgroundMesh.xMin $:backgroundMesh.yMin $:backgroundMesh.zMin) ($:backgroundMesh.xMax $:backgroundMesh.yMin $:backgroundMesh.zMin) ($:backgroundMesh.xMax $:backgroundMesh.yMax $:backgroundMesh.zMin) ($:backgroundMesh.xMin $:backgroundMesh.yMax $:backgroundMesh.zMin) ($:backgroundMesh.xMin $:backgroundMesh.yMin $:backgroundMesh.zMax) ($:backgroundMesh.xMax $:backgroundMesh.yMin $:backgroundMesh.zMax) ($:backgroundMesh.xMax $:backgroundMesh.yMax $:backgroundMesh.zMax) ($:backgroundMesh.xMin $:backgroundMesh.yMax $:backgroundMesh.zMax) ); blocks ( hex (0 1 2 3 4 5 6 7) ( $:backgroundMesh.xCells $:backgroundMesh.yCells $:backgroundMesh.zCells ) simpleGrading ( ( (0.23 0.2 0.2) (0.065 0.3 1) (0.705 0.5 5) ) ( (0.47 0.1 0.1) (0.06 0.4 1) (0.47 0.5 5) ) 1 ) ); edges ( ); boundary ( // Uncomment below to define patches in background mesh /**/ lados { type symmetry; faces ( (0 3 7 4) (1 5 6 2) ); } salida { type patch; faces ( (0 1 2 3) ); } arriba { type patch; faces ( (3 7 6 2) ); } entrada { type patch; faces ( (4 7 6 5) ); } dummy { type wall; faces ( (0 4 5 1) ); } ); mergePatchPairs ( ); |
June 2, 2022, 01:11 |
M
Rep Power: 12 |
Snappy has a hard time working on cells with big aspect ratios coming from blockMesh. I am not aware of a general solution to this. Try decreasing the aspect ratios especially at boundaries to improve the snapping.
Also, its favorable to put the nodes you create in blockMesh in very close proximity to the final position defined by the boundary. |
June 2, 2022, 15:34 |
#3 | |
Christian Pinzón
Rep Power: 4 |
June 3, 2022, 01:16 |
M
Rep Power: 12 |
Hm, I assume it is not an issue of good or bad practise. In a situation like yours, I would definetly use grading as well, to save on computational resources where its not needed and improve resolution where its required.
You just have to deal with snappy not being able to work so well with the background mesh and you need to put more time into resolving this. Usually, I use the ESI version of snappy, which allows you to insert anisotropic splits of the mesh, e.g. only in one direction, in contrast to the foundation version, where you can only refine to a certain level in all 3 directions. Making splits 1 direction at a time helps snappy to make cleaner transitions of levels, especially at the boundaries. But this requires some effort on your part to create refinement regions. |
Calculating flow through an area | i621148 | CFX | 17 | April 10, 2019 16:45 |
Computing and setting reference area in journal | Haukinger | FLUENT | 1 | January 31, 2010 18:11 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
Storing Surface Area of each cell in a file? | Markus Alzon | FLUENT | 0 | June 21, 2007 08:38 |
report surface area WITHOUT solit | Ralf Schmidt | FLUENT | 1 | June 1, 2007 10:23 |
