[mesh manipulation] .msh fiel to OpenFoam mesh |
July 1, 2022, 08:48 |
Daniel Jara Heredia
Rep Power: 5 |
Dear all,
I have a .msh file and I would like to convert it into a vtk file in oder to provide it to gmsh. A collegue told me that he did it once by importing the .msh file into OpenFoam and then exporting it as vtk file. Since I have never used OpenFoam I am somehow lost. I have installed OpenFoam into the WSL in windows (ubuntu version). I have put on a folder the mesh that I what to convert and run the command Fluent3DMeshToFoam but obviously it has failed, since I have not added a system and constant subfolders. So, my question is the following how should I do the the controlDict, fvSchemes and fvSolution and the constant directories in order to run such command? And once I am able to run the command that I desired to run, how I should run FoamToVTK? Thanks Best regards Dani |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 25 | August 14, 2022 13:55 |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
