[snappyHexMesh] SnappyHexMesh doesnt refine in one direction |
July 7, 2022, 09:18 |
Gustavo
Rep Power: 4 |
I am trying to use the snappyhexmesh to refine the mesh around the channel. I create a blockMesh with 2x2x2 cells and I would like to delimit and refine inside my stl file that represents the channel. But the quality of the cells after the snappyHexMesh doesnt look good. I would like cell around the boundaries of the stl file to be smoother. And on the y-axis the cells are bigger than another axis. I've tried a lot of things but I dont know how to improve. Can someone help me? I attached the results of the blockMesh, snappyHexMesh and the case. Thanks a lot. |
July 7, 2022, 10:11 |
Yann
Rep Power: 26 |
Hi Gustavo,
First thing: your STL looks pretty bad (see screenshot). I would not expect to get a clean mesh out of a bad STL file. Second thing: the STL file does not fully intersect the blockMesh domain so snappy does not remove the unwanted part of the mesh when I try to mesh it. By the way: which version of OpenFOAM are you using? Regards Yann |
July 7, 2022, 10:52 |
Gustavo
Rep Power: 4 |
Hi Yann, thanks a lot.
Now I've atacched the case in the correct domain. The stl original is to big to be attached on the forum, so I cut it but I didnt test the case. Sorry about the that. Really the stl file is very bad, I wasted some time filling the holes after I receveid it. But the first ~120 meters on the x-axis doesnt look too bad, dind it? And it is the main region of interest, and I'd expect that snappyHexMesh refine a little better mainly in the y-axis direction, or not? By the way I'am using the openfoam9. Thanks again. |
July 7, 2022, 13:16 |
Yann
Rep Power: 26 |
OK so, this is a fun one!
Your geometry is very far away from the origin of the coordinate system: the STL file coordinates are about 6e6-7e6 meters. The default mergeTolerance in snappyHexMeshDict is 1e-6 and the default writePrecision in controlDict is 6. It basically means you have a precision of 1 meter on your mesh, which explains the poor resolution you get on your mesh. I translated your STL closer to the origin with this command: Code:
surfaceTransformPoints "translate=(-666791 -7.77586e+06 -729.012)" constant/triSurface/canal9.stl constant/triSurface/canal9_translated.stl You could probably also fix it by increasing the mergeTolerance and writePrecision, but I did not try it so I don't know if something else could mess up the mesh. Cheers, Yann |
July 7, 2022, 13:32 |
Gustavo
Rep Power: 4 |
Looks great! Thank you so much! Do you know why snappyHexMesh needs to work with the domain near the origin?
July 8, 2022, 03:33 |
Yann
Rep Power: 26 |
I think this is only a matter of precision: with the default writePrecision of 6, if your coordinate is 100000m, then the nodes coordinates will have a precision down to the meter.
If the coordinate is 1m instead, the nodes coordinates will have a precision down to the hundredth of millimeter. I think this is why you had this weird behavior where cells seem to be elongated along the y-axis: the coordinates get truncated with a precision lower than the actual cell size and this leads to distorted cells. I am not sure my explanations are very clear, but if you want to have a look for yourself, change the write format from binary to ascii in your controlDict, and then compare the constant/polyMesh/points file of your original case with the one of the case I posted. Regards, Yann |
[snappyHexMesh] SnappyHexMesh in 2D case | sjs | OpenFOAM Meshing & Mesh Conversion | 12 | November 8, 2019 04:51 |
[mesh manipulation] How to use refineHexMesh just in 2 direction? | ripperjack | OpenFOAM Meshing & Mesh Conversion | 8 | May 31, 2014 13:43 |
Changing inflow velocity direction deteriorates lift and drag | ziggo | FLUENT | 3 | July 24, 2013 08:39 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
