[blockMesh] face 0 in patch 2 does not have neighbour cell face: 4(0 8 12 4) ERROR |
July 6, 2022, 21:57 |
Gaurav Kumar
Rep Power: 3 |
Hi, I am trying to execute this blockMesh file. It has 3 blocks connected to one another. Kinda simple geometry but I am not sure why I am getting this error. Please help!
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // scale 0.001; vertices ( (0 0 0) //0hex1 (1 0 0) //1hex1 (1 20 0) //2hex3 (0 20 0) //3hex3 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // (0 0 1) //4hex1 (1 0 1) //5hex1 (1 20 1) //6hex3 (0 20 1) //7hex3 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // (0 3 0) //8hex1hex2 (1 3 0) //9hex1hex2 (0.7 18 0) //10hex2hex3 (0.3 18 0) //11hex2hex3 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // (0 3 1) //12hex1hex2 (1 3 1) //13hex1hex2 (0.7 18 1) //14hex2hex3 (0.3 18 1) //15hex2hex3 ); blocks ( hex (0 1 9 8 4 5 12 13) (20 20 1) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (20 20 1) simpleGrading (1 1 1) hex (11 10 2 3 15 14 6 7) (20 20 1) simpleGrading (1 1 1) ); edges ( ); boundary ( inlet { type patch; faces ( (1 5 4 0) ); } atmosphere { type patch; faces ( (3 7 6 2) ); } walls { type wall; faces ( (0 8 12 4) (12 8 11 15) (11 15 7 3) (1 5 13 9) (9 13 14 10) (10 14 6 2) ); } frontAndBack { type empty; faces ( (0 1 9 8) (8 9 10 11) (11 10 2 3) (4 5 13 12) (12 13 14 15) (15 14 6 7) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // |
July 6, 2022, 23:00 |
#2 | |
Gaurav Kumar
Rep Power: 3 |
It is all about correct numbering in hex () syntax as per the faces. |
blockmesh mesh conversion, openfoam |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
