[Technical] is there any way to get cell surface area? |
July 21, 2022, 13:18 |
Rep Power: 3 |
I know that magSf() function can calculate individual face area. However, I want to know the surface area of a cell just like we can get cell volume by using mesh.V().
Does anyone know how to get the cell surface area? Thanks in advance ! |
July 22, 2022, 05:43 |
Mark Olesen
Rep Power: 40 |
I don't know where that would normally be needed, so there is no such functionality. However, writing it yourself is not actually too hard I think.
The basic algorithm would entail the following:
July 22, 2022, 13:35 |
Rep Power: 3 |
Hello olesen,
Thank you for your response ! I just want to know where I would need to write this code? in src/OpenFOAM/meshes/primitiveMesh/ there are two files namely primitiveMeshCellCentresAndVols.C and primitiveMeshFaceCentresAndAreas.C . Do I need to write the code in one of these files or I have to create separate .C file. |
July 31, 2022, 12:17 |
Rep Power: 3 |
Foam::tmp<Foam::scalarField> Foam::cellQuality::cellSurfaceArea() const
{ tmp<scalarField> tresult ( new scalarField ( mesh_.nCells(), 0.0 ) ); scalarField& result = tresult.ref(); scalar sumCellArea; forAll(result,celli) { const labelList& cellFaces = mesh_.cells()[celli]; //with this line, I expect to access the faces belonging to cell under consideration. const vectorField& areas = mesh_.faceAreas(); forAll(cellFaces,facei) { sumCellArea=0; sumCellArea+=mag(areas[facei]); } result[celli]=sumCellArea; } return tresult; } I am trying to find cell surface area. For this, I am trying to access faces belonging to the particular cell and sum their face areas and assign the sum value to 'result' scalar Field whose size is equal to nCells. Please let me know, if the way I have written code is correct logically. Last edited by AbhishekTAMU; July 31, 2022 at 16:19. |
Surface area of each cell for mean beam length calculation | chloe612 | OpenFOAM Programming & Development | 0 | April 14, 2021 00:12 |
[snappyHexMesh] snappyHexMesh generates not planar surface | krzychu111 | OpenFOAM Meshing & Mesh Conversion | 2 | April 23, 2020 16:38 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] Problem with Sanpper, surface still Rough | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 7 | November 5, 2014 12:05 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
