[snappyHexMesh] Weird snappy behaviour
Like Tree1Likes
  • 1 Post By AtoHM
Old   November 3, 2022, 08:52
Default Weird snappy behaviour
Ilan
Magistrane is on a distinguished road
Hello Foamers,
I am working of a 2D project containing a very particular airfoil. It has a curvature on its middle.
As i am on a research suject, I need to proceed a mesh convergence around it.
My problem is : I am trying to keep my close wall layers and decrease the size of the close wall cells. But the curvature of my profile seems difficult to mesh for snappy. See the figures attached.
Has any of you any idea how to solve this ??
I tried to change : minThickness, nGrow, nSolveIter, nCellsBetweenLevels, resolveFeatureAngle without any succes up to now. And also to use the surfaceFeatureExtract function as well.
Thank you for your help !
Magi
Please find my snappyHexMesh bellow :
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  9
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       true;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
    "airfoil.stl"
        type    triSurfaceMesh;
        name    wing_1;
/*    refinementBox
        type    searchableBox;
        min     (-1 -1 -1);
        max     ( 5  1  1);
// Settings for the castellatedMesh generation.
castellatedMeshControls
    // Refinement parameters
    // If local number of cells is >= maxLocalCells on any processor
    // switches from from refinement followed by balancing
    // (current method) to (weighted) balancing before refinement.
    maxLocalCells 100000;
    // Overall cell limit (approximately). Refinement will stop immediately
    // upon reaching this number so a refinement level might not complete.
    // Note that this is the number of cells before removing the part which
    // is not 'visible' from the keepPoint. The final number of cells might
    // actually be a lot less.
    maxGlobalCells 2000000;
    // The surface refinement loop might spend lots of iterations refining just
    // a few cells. This setting will cause refinement to stop if <=
    // minimumRefine are selected for refinement. Note: it will at least do one
    // iteration (unless the number of cells to refine is 0)
    minRefinementCells 100;
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
    nCellsBetweenLevels 15;
    // Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features ();
    // Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
    refinementSurfaces
        wing_1
            // Surface-wise min and max refinement level
            level (6 6);
    // Resolve sharp angles on fridges
    resolveFeatureAngle 170;
    // Region-wise refinement
    // Specifies refinement level for cells in relation to a surface. One of
    // three modes
    // - distance. 'levels' specifies per distance to the surface the
    //   wanted refinement level. The distances need to be specified in
    //   descending order.
    // - inside. 'levels' is only one entry and only the level is used. All
    //   cells inside the surface get refined up to the level. The surface
    //   needs to be closed for this to be possible.
    // - outside. Same but cells outside.
    refinementRegions
    // Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
    locationInMesh (-0.5 0 0);
    // Whether any faceZones (as specified in the refinementSurfaces)
    // are only on the boundary of corresponding cellZones or also allow
    // free-standing zone faces. Not used if there are no faceZones.
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    //- Number of patch smoothing iterations before finding correspondence
    //  to surface
    nSmoothPatch 3;
    //- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
    tolerance 4.0;
    //- Number of mesh displacement relaxation iterations.
    nSolveIter 30;
    //- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
    nRelaxIter 5;
// Settings for the layer addition.
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes true;
    // Per final patch (so not geometry!) the layer information
    layers
        wing_1
            nSurfaceLayers 7;
    // Expansion factor for layer mesh
    expansionRatio 1.3;
    // Wanted thickness of final added cell layer. If multiple layers
    // is the thickness of the layer furthest away from the wall.
    // Relative to undistorted size of cell outside layer.
    // See relativeSizes parameter.
    finalLayerThickness 0.7;
    // Minimum thickness of cell layer. If for any reason layer
    // cannot be above minThickness do not add layer.
    minThickness 0.01;
    // If points get not extruded do nGrow layers of connected faces that are
    // also not grown. This helps convergence of the layer addition process
    // close to features.
    // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
    nGrow 10;
    // Advanced settings
    // When not to extrude surface. 0 is flat surface, 90 is when two faces
    // are perpendicular
    featureAngle 80;
    // Maximum number of snapping relaxation iterations. Should stop
    nRelaxIter 10;
    // Number of smoothing iterations of surface normals
    nSmoothSurfaceNormals 1;
    // Number of smoothing iterations of interior mesh movement direction
    nSmoothNormals 3;
    // Smooth layer thickness over surface patches
    nSmoothThickness 10;
    // Stop layer growth on highly warped cells
    maxFaceThicknessRatio 0.5;
    // Reduce layer growth where ratio thickness to medial
    // distance is large
    maxThicknessToMedialRatio 0.3;
    // Angle used to pick up medial axis points
    // Note: changed(corrected) w.r.t 16x! 90 degrees corresponds to 130 in 16x.
    minMedialAxisAngle 90;
    // Create buffer region for new layer terminations
    nBufferCellsNoExtrude 0;
    // Overall max number of layer addition iterations. The mesher will exit
    // if it reaches this number of iterations; possibly with an illegal
    // mesh.
    nLayerIter 50;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    //- Maximum non-orthogonality allowed. Set to 180 to disable.
    maxNonOrtho 65;
    //- Max skewness allowed. Set to <0 to disable.
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    //- Max concaveness allowed. Is angle (in degrees) below which concavity
    //  is allowed. 0 is straight face, <0 would be convex face.
    //  Set to 180 to disable.
    maxConcave 80;
    //- Minimum pyramid volume. Is absolute volume of cell pyramid.
    //  Set to a sensible fraction of the smallest cell volume expected.
    //  Set to very negative number (e.g. -1E30) to disable.
    minVol 1e-13;
    //- Minimum quality of the tet formed by the face-centre
    //  and variable base point minimum decomposition triangles and
    //  the cell centre.  Set to very negative number (e.g. -1E30) to
    //  disable.
    //     <0 = inside out tet,
    //      0 = flat tet
    //      1 = regular tet
    minTetQuality 1e-30;
    //- Minimum face area. Set to <0 to disable.
    minArea -1;
    //- Minimum face twist. Set to <-1 to disable. dot product of face normal
    //  and face centre triangles normal
    minTwist 0.05;
    //- Minimum normalised cell determinant
    //  1 = hex, <= 0 = folded or flattened illegal cell
    minDeterminant 0.001;
    //- minFaceWeight (0 -> 0.5)
    minFaceWeight 0.05;
    //- minVolRatio (0 -> 1)
    minVolRatio 0.01;
    //must be >0 for Fluent compatibility
    minTriangleTwist -1;
    // Advanced
    //- Number of error distribution iterations
    nSmoothScale 4;
    //- Amount to scale back displacement at error points
    errorReduction 0.75;
// Advanced
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
Magistrane is offline   Reply With Quote
Old   November 19, 2022, 13:04
M
AtoHM is on a distinguished road
Hi, interesting case.
I have not seen cellsBetweenLevels used like that (this high) but it seems legit. The approach seems to make some troubles there.
Maybe another one helps: try using refinement based on distance to the stl. You can prescribe level-distance pairs and I expect that to work more reliably. Check here https://doc.cfd.direct/openfoam/user.../snappyhexmesh at 5.4.5. It should work for stl regions and refinement regions alike.
AtoHM is offline   Reply With Quote
Old   November 21, 2022, 09:00
Ilan
Hey !
Thank you for your answer !
Sorry, I forgot to mention it but I already tried this solution.
It is indeed solving my local problems by refining the mesh in the difficult area... buuuut, it suppress all the layers that I had before. Please fine the image attached.
In snappy's log is written :
Layer addition iteration 1
Determining displacement for added points according to pointNormal ...
Detected 0 points with point normal pointing through faces.
Reset displacement at 0 points to average of surrounding points.
Detected 49302 illegal faces (concave, zero area or negative cell pyramid volume)
Extruding 112 out of 31541 faces (0.355093%). Removed extrusion at 0 faces.
Added 256 out of 220787 cells (0.115949%).
That's the reason why I changed my mesh solution...
Any idea ?
Old   November 22, 2022, 02:22
M
The airfoil edge looks pretty bumpy, which probably prevents the layer generation. The features () dictionary might help in this case. Specify the edge refinement there with the same level as surface refinement.
Anyhow, looking closely, also the distance calculation appears weird in this region, can you share the stl file?
Yann likes this.
[blockMesh] Weird behaviour of spline-edge lhiapgpeonk OpenFOAM Meshing & Mesh Conversion 1 September 22, 2021 06:12
Velocity weird behaviour cinclus FLUENT 0 April 1, 2015 01:45
Weird Behaviour Michael-STM FLUENT 4 March 14, 2014 14:15
[snappyHexMesh] weird behaviour snappyhexmesh FerdiFuchs OpenFOAM Meshing & Mesh Conversion 2 March 7, 2014 09:38
twoPhaseEulerFoam - weird behaviour grjmell OpenFOAM Running, Solving & CFD 5 May 22, 2012 05:07
