October 29, 2022, 00:35 |
Problem with running blockMesh
Yoshi Yagi
Rep Power: 3 |
Hi All,
I am totally new to the world of openFoam and I have been trying to follow along with this tutorial: https://eddylicious.readthedocs.io/e...nnel_lund.html In particular, I am stuck on step 4 in which the tutorial asks me to run "blockMesh." My problem is that I am running into fatal errors when I run "blockMesh" in the terminal. I am using Ubuntu 22 and OpenFOAM 10. I have tried running blockMesh from different directories within the precursor folder, but always end up with some Fatal Error. These are the errors I am getting: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Not deleting polyMesh directory "/home/yoshiyagi/eddylicious/tutorials/channel_flow_lund_rescaling/precursor/constant/polyMesh" because it contains blockMeshDict Reading "blockMeshDict" --> FOAM FATAL ERROR: Cannot find file "system/blockMeshDict" From function int main(int, char**) in file blockMesh.C at line 159. FOAM exiting ************************************************** *********************************** Upon looking at the "/home/yoshiyagi/eddylicious/tutorials/channel_flow_lund_rescaling/precursor/system" folder, I indeed cannot find the file "blockMeshDict" However, I do see a file named "blockMeshDict" in /home/yoshiyagi/eddylicious/tutorials/channel_flow_lund_rescaling/precursor/constant/polyMesh. These are the files in the polyMesh folder: blockMeshDict blockMeshDict.template channelMesh.py I tried running "blockMesh" wtihin the above directory, but got another error: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL ERROR: cannot find file "/home/yoshiyagi/eddylicious/tutorials/channel_flow_lund_rescaling/precursor/constant/polyMesh/system/controlDict" From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 539. FOAM exiting ************************************************** *************** I am at a loss in this tutorial as I think I have tried running blockMesh in other directories, but always get an error. Perhaps this issue is due to my inexperience with openFOAM and that I do not have the right environment or I am not calling blockMesh properly? Any help would be greatly appreciated. I also wanted to add that I also tried running the above commands using "sudo." ***************UPDATE***************************** * I got blockMesh to run, but I am not sure if what I did was the right thing to do. I noticed that my errors were related to the directory "system/blockMeshDict". So, what I did was copy the "system" folder to within the "/home/yoshiyagi/eddylicious/tutorial/channel_flow_lund_rescaling/precursor/constant/polyMesh". I did this because the "controlDict" file was within the "system" folder, but the "system" folder was not located in the same directory as "blockMeshDict". I also had to copy "blockMeshDict" into the copied "system" folder. This is what my directory and its contents looks like now: ************************************************** *********** /home/yoshiyagi/eddylicious/tutorials/channel_flow_lund_rescaling/precursor/constant/polyMesh This is where I ran blockMesh and it worked. This is where I added the files blockMeshDict /home/yoshiyagi/eddylicious/tutorials/channel_flow_lund_rescaling/precursor/constant/polyMesh/system the contents are: blockMeshDict decomposeParDict fvOptions fvSolution controlDict decomposeParDict~ fvSchemes sampleDict ************************************************** ********************************* blockMesh now works, but could someone confirm if this was the right method to getting blockMesh to work? |
November 2, 2022, 14:43 |
Al Csc
Rep Power: 7 |
Yes, blockMeshDict used to be in constant/polyMesh (probably still in extend version). Now it is in system forlder
November 2, 2022, 18:11 |
Yoshi Yagi
Rep Power: 3 |
Hi! Thanks for replying! I see, so the newer version of OpenFOAM is organized differently than older versions? The problem is that the tutorial was made with an older version of OpenFOAM then?
November 2, 2022, 23:49 |
Al Csc
Rep Power: 7 |
Older or different the link you posted is broken, so i have no detail. If it runs and you can validate the results, I won't bother if I were you.
Cheers! |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 18:11 |
problem running blockMesh in ubuntu terminal (openfoam) | subhsngh | OpenFOAM Running, Solving & CFD | 6 | June 26, 2013 08:02 |
[blockMesh] Problem with blockMesh and my shape | TneurolF | OpenFOAM Meshing & Mesh Conversion | 4 | June 25, 2013 13:52 |
Blockmesh problem with more than one block | sven82 | OpenFOAM Pre-Processing | 1 | June 4, 2013 17:08 |
