May 22, 2015, 11:22 |
splitMeshRegions Error!
amine
Rep Power: 12 |
Can anyone told me why I have an error when I tape this command: Code:
splitMeshRegions -cellZonesOnly Code:
For the cellZonesOnly option all cells have to be in a cellZone. Cell 0 at(-0.37500614 -0.37500185 -0.32501155) is not in a cellZone. There might be more unzoned cells. Thanks. |
May 23, 2015, 07:54 |
Alex
Rep Power: 21 |
Try using
Web site where I present my Master's Thesis: foamingtime.wordpress.com The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in! |
May 24, 2015, 13:35 |
amine
Rep Power: 12 |
Yes, it's work with Code:
splitMeshRegions -cellZones Code:
splitMeshRegions -cellZonesOnly |
May 27, 2015, 06:30 |
amine
Rep Power: 12 |
I have resolved a problem This command Code:
splitMeshRegions -cellZonesOnly Thanks |
September 19, 2016, 02:21 |
Rep Power: 12 |
September 20, 2016, 09:38 |
Rep Power: 20 |
Check your polyMesh directory. Now check if there is a file called cellZones. If there is open it and check how many there are, what the names are etc. Also check if you have a folder called sets. For the cellZones only option to work you need to have a cellZone for every cell in your mesh.
If there is no such file you need to create those zones with topoSet |
August 13, 2020, 04:39 |
#7 | |
Aezid-Ul-Hassan Najmi
Rep Power: 5 |
Thanks |
December 31, 2022, 05:30 |
Reda aftiss
Rep Power: 4 |
Try with this,
blockMesh topoSet splitMeshRegions -cellZonesOnly -overwrite |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
