[snappyHexMesh] blockMesh/snappyHexMesh for refining a coarse mesh
Like Tree1Likes
  • 1 Post By Marpole
Old   October 29, 2020, 05:05
Exclamation blockMesh/snappyHexMesh for refining a coarse mesh
Tom Waits
TomWaits is on a distinguished road
I want to have a mesh that is very coarse (to save on computational costs) except for a cylinder in the middle which I want to be very finely meshed.
I use blockMesh to generate a cube with few grid points
blocks
    hex (0 1 2 3 4 5 6 7) (10 10 10) simpleGrading (1 1 1)
and then I use snappyHexMesh with
 geometry
     cylinder
         type    searchableCylinder;
         point1  (0.0 0.0 0.0);
         point2  (0.0 0.0 10);
         radius  1.0;
and
    refinementRegions
        cylinder
            mode inside;
            levels ((10 10));
in my snappyHexMeshDict. The issue is that because the blockMesh is so coarse, snappyHexMesh can't find the cylinder, and the mesh isn't refined. I can add more grid points in each direction in blockMesh in which case it works but then the mesh far away from the cylinder is too fine.
What is the best workflow for this? How do I create a (very) fine cylinder surrounded by very coarse elements?
Many thanks,
Tom Waits
TomWaits is offline   Reply With Quote
Old   October 29, 2020, 10:14
M
AtoHM is on a distinguished road
The problem with refinementRegions is, that cells must lay inside to be refined. If your blockMesh is too coarse, nothing happens. What you can do is go and grab a CAD tool like FreeCAD, model your cylinder there and import it as slt file. Then you can specify refinementSurfaces to get to your level no matter what the background mesh looks like. I guess you gonna need a cellZone so snappy doesnt cut away the cells inside the cylinder.
Are you sure you want level 10? This might give you an insanely high number of cells.
AtoHM is offline   Reply With Quote
Old   November 1, 2020, 23:35
Default refineMesh
Charles
Marpole is on a distinguished road
First, I would suggest to make the background mesh relative coarse but not too coarse. With a proper background mesh size, the region refinement can work better.
And I might also want to try refineMesh before snappyHexMesh. You can refer to tutorial DTCHullMoving.
ufocfd likes this.
Charles L.
Marpole is offline   Reply With Quote
Old   February 10, 2023, 13:57
Giles Richardson
ufocfd is on a distinguished road
This is a good reply - I have not used refineMesh before, but in the DTCHull case its used to refine the mesh after blockMesh but before snappyHexMesh. I have a similar issue recently with a coarse blockMesh (1m cells) and then trying to do surface refinement of a sphere STL geometry which is also 1m diameter, and it doesn't get refined (at all) because the background mesh is too coarse.
The issue can be resolved (a workaround) by increasing the size of the sphere to 2m diameter OR reducing the size of the background mesh to 0.5m cells. This seems like a flaw in snappyHexMesh, but the use of refineMesh before snappyHexMesh could also be an good option. Another workaround is to use the feature edges instead to refine the whole surface - this can be done by changing your surfaceFeaturesDict includedAngle from 150 to say 179. This has the effect of selecting all edges of your geometry, as long as you specify the feature edge refinement level needed within SHMDict too.
I wonder how many other people have fallen foul of this quirky behaviour in SHM?
ufocfd is offline   Reply With Quote
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
