[snappyHexMesh] Snap phase generating extra small cells next to the surface |
February 13, 2023, 14:10 |
Rafael
I'm trying to generate the mesh from a propeller using snappyHexMesh and everthing looks ok except that snap is generating really small cells across the airfoil surface, as shown in the images.
SnapError.jpg SnapErrors.jpg snapError - crinkle.jpg When seing in the crinkle mode, it looks like it created two cells when it should only be one. It becomes a bigger problem when layering since the layers replicate this weird behaviour. I have already tried to change the minVol parameter of the qualityDict, but the only thing that happened was that more cells were counted as in error at the end of the meshing. Does anyone know some way to fix this? Last edited by r.cabral; February 13, 2023 at 14:11. Reason: Added more information |
airfoil, cells volume, issue, snap |
[snappyHexMesh] sHM - flat-/ double lined cells | pconen | OpenFOAM Meshing & Mesh Conversion | 1 | February 1, 2023 04:40 |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 10:11 |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM Running, Solving & CFD | 6 | January 25, 2019 00:11 |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM | 0 | January 16, 2019 01:16 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
