[mesh manipulation] How to remove an extra domain in split Mesh Region? |
April 1, 2021, 00:54 |
Sunag R A
Rep Power: 6 |
Dear All,
I have created a stl mesh using open3D from point cloud. This mesh was split into two domains as a patch and then added back using "surfaceAdd". Now, this mesh is implemented into snappyHexMeshDict. I mesh is running well. But, when I do splitMeshRegion after some topoSet addition, it creates multiple domains, where my cellZoneRegion has only two regions and I need only these two regions. The splitMeshRegion creates an extra domian which needs to be eliminated or added to the major region. How to do that? I have attached an image where the red color represents the extra domian created. It has only 3 face. Below is the snippet of splitMeshRegion. Region Zone Name ------ ---- ---- 0 1 gland 1 0 tumor 2 -1 domain2 Sizes of interfaces between regions: Interface Region Region Faces --------- ------ ------ ----- 0 0 1 278 1 0 2 3 Here "domain2" is the extra region created. |
March 9, 2023, 11:51 |
Atefeh T
Rep Power: 3 |
Hey,
did you manage to solve this problem? if yes please share it with us because I have exactly the same problem! |
domain, openfoam, snappy hex mesh, splitmeshregions |
Can I achieve better convergence? | sheaker | CFX | 12 | September 19, 2019 15:36 |
Turbomachinery Mass imbalance | sheaker | CFX | 12 | September 5, 2019 08:09 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) | Adam_K | OpenFOAM Running, Solving & CFD | 2 | March 27, 2019 06:51 |
[ICEM] How can I create prism mesh for a 3D domain surrounded by a torus? | lzgwhy | ANSYS Meshing & Geometry | 5 | May 18, 2017 17:10 |
