March 16, 2023, 10:37 |
Flow Over A Cylinder Mesh
amarzooq
I am new to openfoam, and I have been trying to mesh a cylinder inside a square to study turbulence around it. I made the overall shape (I think it is correct) but when I want to define the boundaries, I get an error when I put the face on the right wall (51 34 2 19) (line 215 in the code below). I appreciate any help and advise. Also, is it possible that because the mesh quality is bad I get this error? I dont think it is related but who knows... Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2212 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // scale 1; // Geometric parameters rInner 0.5; rOuter 1; //xmax 7.5; xmax_n 10*$rInner; //left wall location as a function of radius xmax_p 50*$rInner;//right wall location as a function of radius ymax 16*$rInner; zmin -0.5; // Back/front locations zmax 0.5; // Divisions: Radial, quarter circumference, outer region and z-directions. nRadial 20; //cylinder cells nQuarter 10;//the region above, right and left to the cylinder (wake and drag region) nxOuter 40;//x direction cells (cylinder not included) nxOuterRight 200;//x direction cells (cylinder not included) in the right of the cylinder nyOuter 50;//y direction cells (cylinder not included) nz 1; // ---------------- // Derived quantities rInner45 ${{ $rInner * sqrt(0.5) }}; rOuter45 ${{ $rOuter * sqrt(0.5) }}; vertices #codeStream { codeInclude #{ #include "pointField.H" #}; code #{ pointField points ({ /*0*/ { $rInner, 0, $zmin }, /* 1*/ { $rOuter, 0, $zmin }, /* 2*/ { $xmax_p, 0, $zmin },//right wall x positive /* 3*/ { $xmax_p, $rOuter45, $zmin }, //right wall xpositive /* 4*/ { $rOuter45, $rOuter45, $zmin }, /* 5*/ { $rInner45, $rInner45, $zmin }, /* 6*/ { $xmax_p, $ymax, $zmin },//right wall x positive /* 7*/ { $rOuter45, $ymax, $zmin }, /* 8*/ { 0, $ymax, $zmin }, /* 9*/ { 0, $rOuter, $zmin }, /*10*/ { 0, $rInner, $zmin }, /*11*/ { -$rInner, 0, $zmin }, /*12*/ { -$rOuter, 0, $zmin }, /*13*/ { -$xmax_n, 0, $zmin }, /*14*/ { -$xmax_n, $rOuter45, $zmin }, /*15*/ { -$rOuter45, $rOuter45, $zmin }, /*16*/ { -$rInner45, $rInner45, $zmin }, //left wall xnegative /*17*/ { -$xmax_n, $ymax, $zmin },//left wall xnegative /*18*/ { -$rOuter45, $ymax, $zmin },//left wall xnegative //*19*/ {-$rInner, 0, -$zmin }, // 19 will be exactly as point 0 // deleted // /* 20*/ { -$rOuter, 0, -$zmin },//20 will be exactly as point 1 //deleted // /* 21*/ { -$xmax_p, 0, -$zmin },//right wall x positive // 21 will be exactly as point 2 /deleted /*19*/ { $xmax_p, -$rOuter45, $zmin }, //right wall xpositive /* 20*/ { $rOuter45, -$rOuter45, $zmin }, /* 21*/ { $rInner45, -$rInner45, $zmin }, /* 22*/ { $xmax_p, -$ymax, $zmin },//right wall x positive /* 23*/ { $rOuter45, -$ymax, $zmin }, /* 24*/ { 0, -$ymax, $zmin }, /* 25*/ { 0, -$rOuter, $zmin }, /*26*/ { 0, -$rInner, $zmin }, // /*30*/ { $rInner, 0, -$zmin },// 30 will be exactly as point 11 // deleted // /*31*/ { $rOuter, 0, -$zmin },//31 will be exactly as point 12 //deleted // /*32*/ { $xmax_n, 0, -$zmin },//32 will be exactly as point 13 // deleted /*27*/ { -$xmax_n, -$rOuter45, $zmin }, /*28*/ { -$rOuter45, -$rOuter45, $zmin }, /*29*/ { -$rInner45, -$rInner45, $zmin }, //left wall xnegative /*30*/ { -$xmax_n, -$ymax, $zmin },//left wall xnegative /*31*/ { -$rOuter45, -$ymax, $zmin }//left wall xnegative }); // Duplicate z points for zmax const label sz = points.size(); points.resize(2*sz); for (label i = 0; i < sz; ++i) { const point& pt = points[i]; points[i + sz] = point(pt.x(), pt.y(), $zmax); } os << points; #}; }; // Can remove unneeded variables #remove ( "r(Inner|Outer).*" "[xy](min|max)" ) blocks ( // +Y blocks /*0*/ hex (5 4 9 10 37 36 41 42) ($nRadial $nQuarter $nz) grading (1 1 1) //cylinder /*1*/ hex (0 1 4 5 32 33 36 37) ($nRadial $nQuarter $nz) grading (1 1 1) //cylinder /*2*/ hex (1 2 3 4 33 34 35 36) ($nxOuterRight $nQuarter $nz) grading (2 1 1) //+ right /*3*/ hex (4 3 6 7 36 35 38 39) ($nxOuterRight $nyOuter $nz) grading (2 1 1) //corner right /*4*/ hex (9 4 7 8 41 36 39 40) ($nQuarter $nyOuter $nz) grading (1 1 1) //+ top right /*5*/ hex (15 16 10 9 47 48 42 41) ($nRadial $nQuarter $nz) grading (1 1 1) //cylinder /*6*/ hex (12 11 16 15 44 43 48 47) ($nRadial $nQuarter $nz) grading (1 1 1) //cylinder /*7*/ hex (13 12 15 14 45 44 47 46) ($nxOuter $nQuarter $nz) grading (1 1 1) //+ left left /*8*/ hex (14 15 18 17 46 47 50 49) ($nxOuter $nyOuter $nz) grading (1 1 1) //+corner left /*9*/ hex (15 9 8 18 47 41 40 50) ($nQuarter $nyOuter $nz) grading (1 1 1) //+ top left //-Y blocks /*10*/ hex (20 21 26 25 52 53 58 57) ($nRadial $nQuarter $nz) grading (1 1 1) //cylinder /*11*/ hex (21 20 1 0 53 52 33 32) ($nRadial $nQuarter $nz) grading (1 1 1) //cylinder /*12*/ hex (20 19 2 1 51 34 33 52) ($nQuarter $nxOuterRight $nz) grading (2 1 1) //+ right right /*13*/ hex (23 22 19 20 55 54 51 52) ($nxOuterRight $nyOuter $nz) grading (2 1 1) //corner right /*14*/ hex (24 23 20 25 56 55 52 57) ($nQuarter $nyOuter $nz) grading (1 1 1) //+ bottom right /*15*/ hex (25 26 29 28 57 58 61 60) ($nRadial $nQuarter $nz) grading (1 1 1) //cylinder /*16*/ hex (28 29 11 12 60 61 43 44) ($nRadial $nQuarter $nz) grading (1 1 1) //cylinder /*17*/ hex (27 28 12 13 59 60 44 45) ($nxOuter $nQuarter $nz) grading (1 1 1) //+left left /*18*/ hex (30 31 28 27 62 63 60 59) ($nxOuter $nyOuter $nz) grading (1 1 1) //corner left /*19*/ hex (31 24 25 28 63 56 57 60) ($nQuarter $nyOuter $nz) grading (1 1 1) //+bottom left ); edges ( // Inner cylinder arc 0 5 origin (0 0 $zmin) arc 5 10 origin (0 0 $zmin) arc 1 4 origin (0 0 $zmin) arc 4 9 origin (0 0 $zmin) arc 0 21 origin (0 0 $zmin) arc 21 26 origin (0 0 $zmin) arc 1 20 origin (0 0 $zmin) arc 20 25 origin (0 0 $zmin) arc 32 53 origin (0 0 $zmax) arc 53 58 origin (0 0 $zmax) arc 33 52 origin (0 0 $zmax) arc 52 57 origin (0 0 $zmax) arc 32 37 origin (0 0 $zmax) arc 37 42 origin (0 0 $zmax) arc 33 36 origin (0 0 $zmax) arc 36 41 origin (0 0 $zmax) // Intermediate cylinder arc 11 16 origin (0 0 $zmin) arc 16 10 origin (0 0 $zmin) arc 12 15 origin (0 0 $zmin) arc 15 9 origin (0 0 $zmin) arc 43 48 origin (0 0 $zmax) arc 48 42 origin (0 0 $zmax) arc 44 47 origin (0 0 $zmax) arc 47 41 origin (0 0 $zmax) arc 11 29 origin (0 0 $zmin) arc 29 26 origin (0 0 $zmin) arc 12 28 origin (0 0 $zmin) arc 28 25 origin (0 0 $zmin) arc 43 61 origin (0 0 $zmax) arc 61 58 origin (0 0 $zmax) arc 44 60 origin (0 0 $zmax) arc 60 57 origin (0 0 $zmax) ); boundary ( down { type symmetryPlane; faces ( (30 31 63 62) (31 24 56 63) (24 23 55 56) (23 22 54 55) ); } right { type patch; faces ( (38 6 3 35) (35 3 2 34) (51 19 22 54) (51 34 2 19) //This is the line that is producing the error ); } up { type symmetryPlane; faces ( (17 18 50 49) (18 8 40 50) (8 7 39 40) (7 6 38 39) ); } Left { type patch; faces ( (17 14 46 49) (14 13 45 46) (13 27 59 45) (27 30 62 59) ); } cylinder { type wall; faces ( (10 5 37 42) (5 0 32 37) (16 10 42 48) (11 16 48 43) (0 21 53 32) (21 26 58 53) (26 29 61 58) (29 11 43 61) ); } ); mergePatchPairs ( ); // ************************************************************************* // when I run checkMesh (while ignoring the line that produces the error) I get: Code:
Create time Create mesh for time = 0 Time = 0 Mesh stats points: 66462 internal points: 0 faces: 130430 internal faces: 63970 cells: 32400 faces per cell: 6 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 32400 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. ***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 2 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" <<Writing region 0 with 30400 cells to cellSet region0 <<Writing region 1 with 2000 cells to cellSet region1 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology down 260 522 ok (non-closed singly connected) right 110 224 ok (non-closed singly connected) up 260 522 ok (non-closed singly connected) Left 120 242 ok (non-closed singly connected) cylinder 80 160 ok (non-closed singly connected) defaultFaces 65630 66462 ok (non-closed singly connected) Checking faceZone topology for multiply connected surfaces... No faceZones found. Checking basic cellZone addressing... No cellZones found. Checking basic pointZone addressing... No pointZones found. Checking geometry... Overall domain bounding box (-5 -8 -0.5) (25 8 0.5) Mesh has 0 geometric (non-empty/wedge) directions (0 0 0) Mesh has 0 solution (non-empty) directions (0 0 0) ***Number of edges not aligned with or perpendicular to non-empty directions: 34501 <<Writing 18040 points on non-aligned edges to set nonAlignedEdges Boundary openness (-4.81024e-19 -2.92463e-17 9.85443e-15) OK. Max cell openness = 2.16877e-15 OK. Max aspect ratio = -1 OK. Minimum face area = 0.00100526. Maximum face area = 2.00203. Face area magnitudes OK. Min volume = 0.00100526. Max volume = 0.0245554. Total volume = 473.538. Cell volumes OK. Mesh non-orthogonality Max: 87.9602 average: 20.2095 *Number of severely non-orthogonal (> 70 degrees) faces: 3790. Non-orthogonality check OK. <<Writing 3790 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. ***Max skewness = 58.4839, 2486 highly skew faces detected which may impair the quality of the results <<Writing 2486 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 2 mesh checks. End The face that doesnt mesh: mesh.JPG |
#mesh /blockmesh |
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 17:22 |
FLow past cylinder. Mesh independency test | beattacz | FLUENT | 6 | April 26, 2020 15:44 |
[ICEM] Bad Quality Hybrid Mesh External Flow | tim13 | ANSYS Meshing & Geometry | 0 | March 8, 2020 02:22 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
